I have found several problems and questions I struggle to find aswers for and would appreciate any help:
- If I run desktop for long enough the panels turn pure black after unlocking computer until I restart DE. Can anything be done about it? I can set it to restart every N hours as it doesn’t seem as of now to break stuff but proper solution would be nice.
- Is it possible to set horizontal scrolling in a way that it would use vertical (mouse) scrolling wheel by default if there is no vertical scrollbar?
Pressing ALT is doable but it slows me much. - Is it possible to reduce icons-only task manager small previews further?
It is related to the second problem, I have a dozen windows open and having to scroll them with keyboard button pressed is not comfortable at all. Currently using “large previews” option but sometimes it fails if I run anything fullscreen on the other monitor. - I have two displays and 3 virtual desktops. Occasionally some my windows on one of virtual desktops shift from main displays to secondary displays. It happens almost all the time if I leave it for a while and DE locks itself, then when I come back some of the windows are shifted to secondary display.
On the first login screen after boot the secondary display is threated as main display, I think.
