KDE Plasma 6 wayland return to SDDM login
Update KDE to 6 and I want to use wayland but when enter the password on SDDM login screen turn black and after 2-3 sec return to SDDM login page.
I used closed-source nvidia driver turn it to open-source one and problem still here.
X11 works fine BTW.
Which video card do you have?
$ inxi -Ga
  Device-1: Intel 4th Gen Core Processor Integrated Graphics vendor: Lenovo driver: i915 v: kernel
    arch: Gen-7.5 process: Intel 22nm built: 2013 ports: active: eDP-1 empty: HDMI-A-1,VGA-1
    bus-ID: 00:02.0 chip-ID: 8086:0416 class-ID: 0300
  Device-2: NVIDIA GK208M [GeForce GT 740M] vendor: Lenovo driver: N/A alternate: nouveau
    non-free: series: 470.xx+ status: legacy-active (EOL~2024-09-xx) arch: Kepler code: GKxxx
    process: TSMC 28nm built: 2012-2018 pcie: gen: 1 speed: 2.5 GT/s lanes: 8 link-max: gen: 3
    speed: 8 GT/s bus-ID: 07:00.0 chip-ID: 10de:1292 class-ID: 0302
Try running on the modesetting intel driver, remove xf86-video-intel and reboot.
Don’t know how to do it.
sudo pacman -R xf86-video-intel
Uhuh I think modeseting is another thing.
so it seems I don’t have that package since
error: target not found: xf86-video-intel
Are you running on the nvidia?
how to know that?
Is that the full output of the inxi command?
$ inxi -Ga
  Device-3: IMC Networks Lenovo EasyCamera driver: uvcvideo type: USB rev: 2.0 speed: 480 Mb/s
    lanes: 1 mode: 2.0 bus-ID: 3-1:2 chip-ID: 13d3:5722 class-ID: 0e02 serial: NULL
  Display: server: X.org v: 1.21.1.11 with: Xwayland v: 23.2.4 driver: X: loaded: modesetting
    alternate: fbdev,intel,vesa dri: crocus gpu: i915 tty: 113x24
  Monitor-1: eDP-1 model: ChiMei InnoLux 0x15bd built: 2012 res: 1366x768 dpi: 101 gamma: 1.2
    size: 344x194mm (13.54x7.64") diag: 395mm (15.5") ratio: 16:9 modes: 1366x768
  API: EGL v: 1.5 hw: drv: intel crocus platforms: device: 0 drv: crocus device: 1 drv: swrast
    surfaceless: drv: crocus inactive: gbm,wayland,x11
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: mesa v: 24.0.3-arch1.2 note: console (EGL sourced)
    renderer: Mesa Intel HD Graphics 4600 (HSW GT2), llvmpipe (LLVM 17.0.6 256 bits)
complete version
You are on Intel, this graphics card is very old (11 years), I’ll see if I can find anything, but off out in a short while.
can we switch it on nvidia?
