Hi,
I’m not sure wheter everyone is experiencing it, Kalu in my laptop is throwing errors at me just as the system starts, and is not waiting for WiFi connection to establish.
I think that calu shoud have some hook in NetworkManager to wait for connection establishing, or at least like 30 seconds sleep after system boot just to make sure that it’s not producing misleading errors.
NetworkManager should start your wifi at boot normally. kalu does not have a systemd service file to start at boot. such as pamac or octopi does have a service at boot. For example, if you do ctrl-alt-f2 as login manager and go to tty , you should have internet but kalu is not loaded in as example. kalu comes in at start up of your desktop
Perhaps my NM config is bit messed, first of all when I boot, I’m waiting for 90 sec timeout with: A start job is running for /sys/subsystem/net/devices/enp0s31f6
I did pretty deep search on that (mostly arch wiki) and still no solution on my mind. I tried sysctl disabling, looking in init.d scripts, even removed some NM dependency - “icu” it was, afair.
I can see for example that WPA-Supplicant gets loaded at boot time, but I think that there’s no attempt to establish wifi connection at boot process, but I may be wrong.
It’s a little annoying, but yes…I’m having a similar issue. After I log in on my laptop, as soon as my desktop loads, Kalu pops up an error that it’s unable to connect. In two seconds, I’m connected to Ethernet according to the next notification. So, I can confirm the problem, but I have no idea how to resolve it unless there’s a way to tell Kalu to wait 10 seconds after login? I’ve DuckDuckGo’d (DDG’d?), and there are ways shown, but not entirely sure if they’re preferred.
It might work by putting kalu as a systemd service to depend on e.g. network-online.target.
I already tried it, but it didn’t work, just got a black screen. Seems like kalu does not work well with systemd.
This was what I tried:
[Unit]
Description=Start kalu when network is available
After=network-online.target
[Service]
Type=idle
ExecStart=/usr/bin/kalu
[Install]
WantedBy=network-online.target
in file /usr/lib/systemd/system/kalu.service, enabled it and rebooted.
I have Wifi on two of my computers with Endeavour and when both boot up they are are automatically connected instantly and kalu runs right after and tells me there are updates or not and it is so fast. I have no issues with it. Wifi doesn’t wait to connect it is connected as soon as i see the desktop it’s there and the kalu icon starts flashing checking for updates. These are desktops not laptops.
No i have it running on my Xfce and Cinnamon desktops. The xfce version is ethernet and the other two cinammon are wifi but all of them have kalu in the startup applications. I have no issues with it on the wifi as my wifi is right there as soon as it starts up.
@patryk and @Adam go to session and startup > automatic started > edit kalu entry by the command bellow.
You can test the better time for you, in the example is 10 seconds.
Ok, but isn’t this ethernet specific?
I know my father notebook usually only connects to wifi along with desktop loading, sometimes is possible to see the wifi icon “searching and connecting” animation
I guess wifi has some delay, not sure exactly how this works when needs to search for a saved password for example, while ethernet is “plug and play”
It is just my thought, if you configure a connection and is for example all, it do running at system boot since :
it is searching for cable. NM does search network but only on wrong adress.
what is te systemctl status dhcpcd.service ?
but thats my thought, NM does load intoo boot even it is Wifi. wifi does work here only issue for me the attic and the wifi is to far since kalu loads after startup has nothing todo on network startup the NM-applet is just a front.
