Jellyfin server help please
From Arch Wiki
Jellyfin runs as user jellyfin, which has no permission for your home directory. If you add a directory inside your home directory to a library, Jellyfin fails to access it. You can create a dedicated directory for Jellyfin.
I have used a dedicated directory /mnt/jellyfin which holds all the media. If you want to access it as a regular user add yourself to group jellyfin and set permissions accordingly. Optionally create a link to your home folder.
@memphis_cult This is the correct solution to your problem. It’s a permissions issue.
ill try and mark as solved
1. Set Directory Ownership and Permissions
bash
Copy
sudo chown -R jellyfin:jellyfin /mnt/jellyfin # Set ownership to jellyfin user and group sudo chmod 2775 /mnt/jellyfin # Enable setgid and set permissions sudo find /mnt/jellyfin -type d -exec chmod g+s {} ; # Ensure setgid is applied recursively (optional)
  • chown -R jellyfin:jellyfin: Makes the jellyfin user and group owners of the directory.
  • chmod 2775: Sets permissions to rwxrwsr-x, allowing the group to read/write/execute and ensuring new files inherit the group.
  • find ... -exec chmod g+s: Applies the setgid bit recursively to subdirectories (optional if using chmod -R 2775).
2. Add Your User to the Jellyfin Group
bash
Copy
sudo usermod -aG jellyfin $USER # Replace $USER with your username if needed
  • This grants your regular user access to the jellyfin group.
3. Reload Group Membership
  • Log out and back in or restart your system for group changes to take effect.
4. (Optional) Create a Symlink in Your Home Directory
bash
Copy
ln -s /mnt/jellyfin ~/jellyfin-media # Creates a shortcut in your home directory
5. Fix Existing File Permissions (If Needed)
bash
Copy
sudo chmod -R g+rwX /mnt/jellyfin # Grants group read/write and directory traversal
  • g+rwX: Adds read/write for the group and ensures directories are executable.
did i do something wrong
Is this from Chat GPT ??
( I expected you to visit the arch wiki :person_shrugging: )
If you have followed the instructions you posted:
  1. you have a folder /mnt/jellyfin owned by user jellyfin.
  2. You can access this folder from your home folder (using a file manager).
  3. You can add any folder created within this jellyfin folder to a jellyfin media library. (I assume you know how to set up libraries in jellyfin)
Only problem with the steps you mentioned is using chmod -R 2775. Using mod 2775 or 775 allows any user to read data from the folder. If you followed these steps already simply run sudo chmod 770 /mnt/jellyfin.
solved it using docker
