Operating System: EndeavourOS
KDE Plasma Version: 6.5.4
KDE Frameworks Version: 6.21.0
Qt Version: 6.10.1
Kernel Version: 6.18.2-arch2-1 (64-bit)
Graphics Platform: Wayland
Processors: 16 × AMD Ryzen 7 5800X 8-Core Processor
Memory: 32 GiB of RAM (31.2 GiB usable)
Graphics Processor: NVIDIA GeForce RTX 2070 SUPER
Manufacturer: ASUS
Hello, I post my Problem here since it’s only appears when playing minecraft.
I did A LOT of testing and don’t want to post a gigantic wall of text so I’ll sum it up.
I have memory leaks when playing minecraft, modded and Vanilla, every possible mod combination there is (and yes memory leak fix mods don’t work).
Different Java arguments, different Vendors, my own or automatically downloaded from Modrinth/Prism Launcher/official launcher, different Java versions make no difference at all.
Everything is up-to-date, and I even did a fresh reinstallation, which did nothing.
I looked at it with VirtualVM, free -m for example, tried spark, which is a performance profiler but nothing showed anything related or of help.
Spark showed me that java hangs at some point for a long of time, but I couldn’t find anything related to that.
Obviously, I looked through every log i could find, but to no avail.
The only place where I can reliably see my Memory leaks is in the default systemmonitor which does seem to be accurate after all that testing.
I’m quite frustrated At this point, because I just don’t know anything what I can do to diagnose or fix my problem anymore.
I also couldn’t find any possible solution online, since it all leads to a dead end.
For logs I need to redo my testing, since I didn’t save them, so that would take a day or two if wanted.
I don’t need a perfect solution, but at least a pointer or two would already help immensely.
