How to do that?
I don’t want to give you the wrong instructions because I’m not 100% on it. I just know that the previous firmware is there. I know how to remove the iwlwifi module and reload it. I’m just not sure on how to make it use that particular firmware. I don’t want to cause a problem for you but i know this may be the issue with the latest firmware.
Edit: Maybe someone can help with that that knows more on it.
Okay i think i know how to do it. First you need to have the downgrade package installed. Then what you need to do is see if the previous firmware package is in /var/cache/pacman/pkg
You are looking for iwlwifi-9000-pu-b0-jf-b0-43.ucode
Install downgrade
yay -S downgrade
So then you can use the downgrade command. I’m not sure if it needs sudo but i assume so.
pacman -U /var/cache/pacman/pkg/linux-firmware-xxxxxx ( this is the name of the firmware)
Edit: I 'm not 100% on this so you may want to get further direction before attempting this. Maybe one of the devs can assist.
sudo pacman -U /var/cache/pacman/pkg/linux-firmware-20200421.78c0348-1-any.pkg.tar.zst
has been issued, rebooted, …will wait and see…
EDIT:
not this one…full lock up after 10 mins
As that is the oldest firmware in my system, and the system used to work without lockups, I think that I may be barking up the wrong tree. Will instead load the LTS kernel, and see if that works.
I’m not sure what those firmware files are? I only know the one you need as i have given. iwlwifi-9000-pu-b0-jf-b0-43.ucode. There are lots of firmware files. They may be for other things. I can’t tell just by the file as i have nothing to refer it to.
You’re right, despite downgrading the firmware file , the old version 46 is still there, still active. I’ll try mv -ing it to see what happens…
The previous file may not exist on your system. It is on mine because i don;'t have iwlwifi so it hasn’t been used. Yours may not exist in the cache after being updated.
Edit: As you say you could try the lts kernel in the mean time.
I have the file on my system.
Yes, I have the file, so moved the 46 version. After reboot:
dmesg | grep firmware
[ 0.324312] Spectre V2 : Enabling Restricted Speculation for firmware calls
[ 3.450745] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-9000-pu-b0-jf-b0-46.ucode failed with error -2
[ 3.451715] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-9000-pu-b0-jf-b0-45.ucode failed with error -2
[ 3.451731] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-9000-pu-b0-jf-b0-44.ucode failed with error -2
[ 3.461659] iwlwifi 0000:00:14.3: loaded firmware version 43.95eb4e97.0 op_mode iwlmvm
With the LTS kernel the system is so far working, but keeps halting for 2mins or so.
Still getting in dmesg:
[ 202.237286] iwlwifi 0000:00:14.3: Unhandled alg: 0x707
I still think you need to add
options iwlwifi swcrypto=0
To this file
/etc/modprobe.d/iwlwifi.conf
Maybe it won’t work but worth trying.
Thanks for trying…
looks like a hardware error. After doing all of the above, dmesg reports:
3.829101] iwlwifi 0000:00:14.3: RF_KILL bit toggled to enable radio.
[ 3.908833] iwlwifi 0000:00:14.3: Hardware error detected. Restarting.
[ 3.908835] iwlwifi 0000:00:14.3: DEVICE_ENABLED bit is not set. Aborting dump.
[ 3.908837] iwlwifi 0000:00:14.3: WRT: Collecting data: ini trigger 4 fired.
[ 3.908839] ieee80211 phy0: Hardware restart was requested
[ 3.914791] iwlwifi 0000:00:14.3: Hardware error detected. Restarting.
[ 3.914991] iwlwifi 0000:00:14.3: Hardware error detected. Restarting.
[ 3.919888] iwlwifi 0000:00:14.3: Firmware not running - cannot dump error
[ 3.927008] iwlwifi 0000:00:14.3: RF_KILL bit toggled to enable radio.
[ 4.030055] iwlwifi 0000:00:14.3: Hardware error detected. Restarting.
[ 4.030056] iwlwifi 0000:00:14.3: DEVICE_ENABLED bit is not set. Aborting dump.
Yet it still works in (ssssh) w10
Maybe goi back to the current file and here are some other options to try.
/etc/modprobe.d/wifi.conf
options iwlwifi lar_disable=1
options iwlwifi bt_coex_active=0
I have tested this hardware under MX Linux 19.2 AHS Live ISO, which is running with the same firmware ( version 46 ) , and kernel 5.6.14. All works fine there. About to downgrade kernel to 5.6.15 as per my cache…
The kernel is now 5.7.4
As a side note on clear linux which is Intels project and the iwlwifi is also Intel.
After trying 5.6.14 and 15, and getting the same result, I wondered about the kernel parameters sent by grub, as they were not active with the MXLinux.
On this laptop I had found that the parameters : quiet irqpoll loglevel=3 pci=nomsi,noaer
had to be passed in order for the hardware to be happy. At a guess, I removed the pci=nomsi,noaer
and found that booting now dmesg | grep iwl gave a vastly different result, and no lockups;
[ 3.456880] iwlwifi: unknown parameter 'lar_disable' ignored
[ 3.457001] iwlwifi 0000:00:14.3: enabling device (0000 -> 0002)
[ 3.466038] iwlwifi 0000:00:14.3: Found debug destination: EXTERNAL_DRAM
[ 3.466039] iwlwifi 0000:00:14.3: Found debug configuration: 0
[ 3.466319] iwlwifi 0000:00:14.3: loaded firmware version 46.6bf1df06.0 9000-pu-b0-jf-b0-46.ucode op_mode iwlmvm
[ 3.825092] iwlwifi 0000:00:14.3: Detected Intel(R) Dual Band Wireless AC 9560, REV=0x318
[ 3.833246] iwlwifi 0000:00:14.3: Applying debug destination EXTERNAL_DRAM
[ 3.833557] iwlwifi 0000:00:14.3: Allocated 0x00400000 bytes for firmware monitor.
[ 3.880451] iwlwifi 0000:00:14.3: base HW address: 0c:dd:24:a6:49:79
[ 3.948266] ieee80211 phy0: Selected rate control algorithm 'iwl-mvm-rs'
[ 4.483503] iwlwifi 0000:00:14.3: Applying debug destination EXTERNAL_DRAM
[ 4.598515] iwlwifi 0000:00:14.3: Applying debug destination EXTERNAL_DRAM
[ 4.664250] iwlwifi 0000:00:14.3: FW already configured (0) - re-configuring
[ 4.694759] iwlwifi 0000:00:14.3: Applying debug destination EXTERNAL_DRAM
[ 4.810715] iwlwifi 0000:00:14.3: Applying debug destination EXTERNAL_DRAM
[ 4.876403] iwlwifi 0000:00:14.3: FW already configured (0) - re-configuring
So thanks, @ricklinux, for sticking with me through this. It’s properly solved now, at least for the moment ![]()
So it is using the latest firmware again.The nomsi is related to pci devices
A Message Signaled Interrupt is a write from the device to a special address which causes an interrupt to be received by the CPU.
Redhat has a why is pci=nomsi needed or recommended by my hardware vendor . Basically they elaborate on how not all machines or chipsets support MSI correctly.
This is complicated stuff but what happens is it reverts to pin based signalling at the hardware level.
PCI devices can only support a single pin-based interrupt per function. Often drivers have to query the device to find out what event has occurred, slowing down interrupt handling for the common case. With MSIs, a device can support more interrupts, allowing each interrupt to be specialized to a different purpose. One possible design gives infrequent conditions (such as errors) their own interrupt which allows the driver to handle the normal interrupt handling path more efficiently. Other possible designs include giving one interrupt to each packet queue in a network card or each port in a storage controller.
This is all in the design of the board from the manufacturer and is complicated engineering level stuff that is above my level of knowledge. ![]()
Anyone else seeing such errors? Specifically wireless network unstable…
iwlwifi 0000:01:00.0: Unhandled alg: 0x71b
Running on a HP Elitebook 845 G7 with Intel AX200 Wifi 6, Kernel 5.9.14-arch1-1
01:00.0 Network controller: Intel Corporation Wi-Fi 6 AX200 (rev 1a)
Was running fine, but not sure when it started… either a linux update or a HP firmware update began to cause this…
Dual boot setup… the Windows side continues to runs fine.
thanks.
3459.041727] wlan0: RX AssocResp from 24:a0:74:76:bb:8b (capab=0x1011 status=0 aid=4)
[ 3459.055040] wlan0: associated
[ 3459.060532] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 3459.095167] audit: type=1130 audit(1609026501.727:147): pid=1 uid=0 auid=4294967295 ses=4294967295 msg=‘unit=NetworkManager-dispatcher comm=“systemd” exe=“/usr/lib/systemd/systemd” hostname=? addr=? terminal=? res=success’
[ 3459.119301] wlan0: Limiting TX power to 17 (17 - 0) dBm as advertised by 24:a0:74:76:bb:8b
[ 3459.131222] audit: type=1111 audit(1609026501.763:148): pid=616 uid=0 auid=4294967295 ses=4294967295 msg=‘op=statistics arg=“refresh-rate-ms” pid=1508 uid=1000 result=success exe=“/usr/bin/NetworkManager” hostname=? addr=? terminal=? res=success’
[ 3462.711063] audit: type=1111 audit(1609026505.343:149): pid=616 uid=0 auid=4294967295 ses=4294967295 msg=‘op=statistics arg=“refresh-rate-ms” pid=1508 uid=1000 result=success exe=“/usr/bin/NetworkManager” hostname=? addr=? terminal=? res=success’
[ 3469.102684] audit: type=1131 audit(1609026511.733:150): pid=1 uid=0 auid=4294967295 ses=4294967295 msg=‘unit=NetworkManager-dispatcher comm=“systemd” exe=“/usr/lib/systemd/systemd” hostname=? addr=? terminal=? res=success’
[ 3506.391595] wlan0: disconnect from AP 24:a0:74:76:bb:8b for new auth to 0c:51:01:e6:b4:d9
[ 3506.407380] wlan0: authenticate with 0c:51:01:e6:b4:d9
[ 3506.419377] wlan0: send auth to 0c:51:01:e6:b4:d9 (try 1/3)
[ 3506.450469] wlan0: authenticated
[ 3506.453322] wlan0: associate with 0c:51:01:e6:b4:d9 (try 1/3)
[ 3506.454983] wlan0: RX ReassocResp from 0c:51:01:e6:b4:d9 (capab=0x1011 status=0 aid=11)
[ 3506.472114] wlan0: associated
[ 3506.516260] wlan0: Limiting TX power to 17 (17 - 0) dBm as advertised by 0c:51:01:e6:b4:d9
[ 3639.286150] wlan0: disconnect from AP 0c:51:01:e6:b4:d9 for new auth to 24:a0:74:76:bb:8b
[ 3639.301487] wlan0: authenticate with 24:a0:74:76:bb:8b
[ 3639.313587] wlan0: send auth to 24:a0:74:76:bb:8b (try 1/3)
[ 3639.345303] wlan0: authenticated
[ 3639.346631] wlan0: associate with 24:a0:74:76:bb:8b (try 1/3)
[ 3639.348487] wlan0: RX ReassocResp from 24:a0:74:76:bb:8b (capab=0x1011 status=0 aid=4)
[ 3639.363596] wlan0: associated
[ 3639.446315] wlan0: Limiting TX power to 17 (17 - 0) dBm as advertised by 24:a0:74:76:bb:8b
[ 3643.438194] iwlwifi 0000:01:00.0: Unhandled alg: 0x71b
[ 3643.783182] iwlwifi 0000:01:00.0: Unhandled alg: 0x71b
[ 3671.678684] wlan0: disconnect from AP 24:a0:74:76:bb:8b for new auth to 34:12:98:08:83:8d
[ 3671.693385] wlan0: authenticate with 34:12:98:08:83:8d
[ 3671.708133] wlan0: send auth to 34:12:98:08:83:8d (try 1/3)
[ 3671.739019] wlan0: authenticated
[ 3671.739950] wlan0: associate with 34:12:98:08:83:8d (try 1/3)
[ 3671.742348] wlan0: RX ReassocResp from 34:12:98:08:83:8d (capab=0x1011 status=0 aid=6)
[ 3671.758709] wlan0: associated
[ 3671.763073] wlan0: Limiting TX power to 17 (17 - 0) dBm as advertised by 34:12:98:08:83:8d
[ 3704.708379] wlan0: disconnect from AP 34:12:98:08:83:8d for new auth to 0c:51:01:e6:b4:d9
[ 3704.723606] wlan0: authenticate with 0c:51:01:e6:b4:d9
[ 3704.737108] wlan0: send auth to 0c:51:01:e6:b4:d9 (try 1/3)
[ 3704.767799] wlan0: authenticated
[ 3704.769951] wlan0: associate with 0c:51:01:e6:b4:d9 (try 1/3)
[ 3704.771621] wlan0: RX ReassocResp from 0c:51:01:e6:b4:d9 (capab=0x1011 status=0 aid=11)
[ 3704.785675] wlan0: associated
[ 3704.869838] wlan0: Limiting TX power to 17 (17 - 0) dBm as advertised by 0c:51:01:e6:b4:d9
[ 3732.202586] iwlwifi 0000:01:00.0: Unhandled alg: 0x71b
[ 3736.503938] wlan0: disconnect from AP 0c:51:01:e6:b4:d9 for new auth to 24:a0:74:76:bb:8b
[ 3736.520387] wlan0: authenticate with 24:a0:74:76:bb:8b
[ 3736.534859] wlan0: send auth to 24:a0:74:76:bb:8b (try 1/3)
[ 3736.568387] wlan0: authenticated
[ 3736.569947] wlan0: associate with 24:a0:74:76:bb:8b (try 1/3)
[ 3736.571752] wlan0: RX ReassocResp from 24:a0:74:76:bb:8b (capab=0x1011 status=0 aid=4)
[ 3736.586957] wlan0: associated
[ 3736.624763] wlan0: Limiting TX power to 17 (17 - 0) dBm as advertised by 24:a0:74:76:bb:8b
[ 3739.439958] iwlwifi 0000:01:00.0: Unhandled alg: 0x71b
[ 3739.439983] iwlwifi 0000:01:00.0: Unhandled alg: 0x71b
[ 3739.735377] iwlwifi 0000:01:00.0: Unhandled alg: 0x71b
[ 3740.297823] iwlwifi 0000:01:00.0: Unhandled alg: 0x71b
[ 3741.091986] iwlwifi 0000:01:00.0: Unhandled alg: 0x71b
[ 3741.219264] iwlwifi 0000:01:00.0: Unhandled alg: 0x71b
[ 3742.448094] iwlwifi 0000:01:00.0: Unhandled alg: 0x71b
[ 3743.370628] iwlwifi 0000:01:00.0: Unhandled alg: 0x71b
[ 3744.291276] iwlwifi 0000:01:00.0: Unhandled alg: 0x71b
[ 3745.214185] iwlwifi 0000:01:00.0: Unhandled alg: 0x71b
[ 3746.749087] iwlwifi 0000:01:00.0: Unhandled alg: 0x71b
[ 3762.725000] iwlwifi 0000:01:00.0: Unhandled alg: 0x71b
[ 3764.566580] iwlwifi 0000:01:00.0: Unhandled alg: 0x71b
[ 3765.487639] iwlwifi 0000:01:00.0: Unhandled alg: 0x71b
[ 3767.492972] iwlwifi 0000:01:00.0: Unhandled alg: 0x71b
[ 3771.632351] iwlwifi 0000:01:00.0: Unhandled alg: 0x71b
[ 3786.992080] iwlwifi 0000:01:00.0: Unhandled alg: 0x71b
[ 3787.921058] iwlwifi 0000:01:00.0: Unhandled alg: 0x71b
[ 3788.835833] iwlwifi 0000:01:00.0: Unhandled alg: 0x71b
[ 3791.908362] iwlwifi 0000:01:00.0: Unhandled alg: 0x71b
[ 3798.973695] iwlwifi 0000:01:00.0: Unhandled alg: 0x71b
[ 3801.124139] iwlwifi 0000:01:00.0: Unhandled alg: 0x71b
[ 3802.045731] iwlwifi 0000:01:00.0: Unhandled alg: 0x71b
[ 3802.882166] wlan0: disconnect from AP 24:a0:74:76:bb:8b for new auth to 34:12:98:08:83:8d
[ 3802.899407] wlan0: authenticate with 34:12:98:08:83:8d
[ 3802.912888] wlan0: send auth to 34:12:98:08:83:8d (try 1/3)
[ 3802.944609] wlan0: authenticated
[ 3802.946619] wlan0: associate with 34:12:98:08:83:8d (try 1/3)
[ 3802.948285] wlan0: RX ReassocResp from 34:12:98:08:83:8d (capab=0x1011 status=0 aid=3)
[ 3802.962571] wlan0: associated
[ 3803.044253] wlan0: Limiting TX power to 17 (17 - 0) dBm as advertised by 34:12:98:08:83:8d
[ 3806.249778] iwlwifi 0000:01:00.0: Unhandled alg: 0x71b
[ 3807.699011] iwlwifi 0000:01:00.0: Unhandled alg: 0x71b
[ 3811.539276] iwlwifi 0000:01:00.0: Unhandled alg: 0x71b
[ 3819.685304] iwlwifi 0000:01:00.0: Unhandled alg: 0x71b
[ 3836.198352] wlan0: disconnect from AP 34:12:98:08:83:8d for new auth to 0c:51:01:e6:b4:d9
[ 3836.214624] wlan0: authenticate with 0c:51:01:e6:b4:d9
[ 3836.230397] wlan0: send auth to 0c:51:01:e6:b4:d9 (try 1/3)
[ 3836.261900] wlan0: authenticated
[ 3836.263273] wlan0: associate with 0c:51:01:e6:b4:d9 (try 1/3)
[ 3836.265460] wlan0: RX ReassocResp from 0c:51:01:e6:b4:d9 (capab=0x1011 status=0 aid=11)
[ 3836.280628] wlan0: associated
[ 3836.352938] wlan0: Limiting TX power to 17 (17 - 0) dBm as advertised by 0c:51:01:e6:b4:d9
[ 3869.197069] wlan0: disconnect from AP 0c:51:01:e6:b4:d9 for new auth to 24:a0:74:76:bb:8b
[ 3869.212293] wlan0: authenticate with 24:a0:74:76:bb:8b
[ 3869.226842] wlan0: send auth to 24:a0:74:76:bb:8b (try 1/3)
[ 3869.257905] wlan0: authenticated
[ 3869.260220] wlan0: associate with 24:a0:74:76:bb:8b (try 1/3)
[ 3869.261762] wlan0: RX ReassocResp from 24:a0:74:76:bb:8b (capab=0x1011 status=0 aid=4)
[ 3869.280259] wlan0: associated
[ 3869.330210] wlan0: Limiting TX power to 17 (17 - 0) dBm as advertised by 24:a0:74:76:bb:8b
[ 3872.439530] iwlwifi 0000:01:00.0: Unhandled alg: 0x71b
[ 3872.439537] iwlwifi 0000:01:00.0: Unhandled alg: 0x71b
[ 3872.439754] iwlwifi 0000:01:00.0: Unhandled alg: 0x71b
[ 3873.312238] iwlwifi 0000:01:00.0: Unhandled alg: 0x71b
[ 3873.625361] iwlwifi 0000:01:00.0: Unhandled alg: 0x71b
[ 3874.547579] iwlwifi 0000:01:00.0: Unhandled alg: 0x71b
[ 3875.468405] iwlwifi 0000:01:00.0: Unhandled alg: 0x71b
[ 3876.390170] iwlwifi 0000:01:00.0: Unhandled alg: 0x71b
[ 3877.618528] iwlwifi 0000:01:00.0: Unhandled alg: 0x71b
[ 3878.539406] iwlwifi 0000:01:00.0: Unhandled alg: 0x71b
[ 3879.460598] iwlwifi 0000:01:00.0: Unhandled alg: 0x71b
[ 3887.756163] iwlwifi 0000:01:00.0: Unhandled alg: 0x71b
[ 3899.736191] iwlwifi 0000:01:00.0: Unhandled alg: 0x71b
[ 3909.873954] iwlwifi 0000:01:00.0: Unhandled alg: 0x71b
[ 3914.180467] iwlwifi 0000:01:00.0: Unhandled alg: 0x71b
[ 3925.234761] iwlwifi 0000:01:00.0: Unhandled alg: 0x71b
[ 3927.075517] iwlwifi 0000:01:00.0: Unhandled alg: 0x71b
[ 3934.142382] iwlwifi 0000:01:00.0: Unhandled alg: 0x71b
[ 3937.214264] iwlwifi 0000:01:00.0: Unhandled alg: 0x71b
[ 3943.674103] iwlwifi 0000:01:00.0: Unhandled alg: 0x71b
[ 3952.575710] iwlwifi 0000:01:00.0: Unhandled alg: 0x71b
[ 3964.555386] iwlwifi 0000:01:00.0: Unhandled alg: 0x71b
[ 3969.039021] wlan0: disconnect from AP 24:a0:74:76:bb:8b for new auth to 0c:51:01:e6:b4:d9
[ 3969.056347] wlan0: authenticate with 0c:51:01:e6:b4:d9
[ 3969.068947] wlan0: send auth to 0c:51:01:e6:b4:d9 (try 1/3)
[ 3969.099342] wlan0: authenticated
[ 3969.099943] wlan0: associate with 0c:51:01:e6:b4:d9 (try 1/3)
[ 3969.101881] wlan0: RX ReassocResp from 0c:51:01:e6:b4:d9 (capab=0x1011 status=0 aid=11)
[ 3969.115817] wlan0: associated
[ 3969.166325] wlan0: Limiting TX power to 17 (17 - 0) dBm as advertised by 0c:51:01:e6:b4:d9
[ 4232.641696] wlan0: disconnect from AP 0c:51:01:e6:b4:d9 for new auth to 34:12:98:08:83:8d
[ 4232.657855] wlan0: authenticate with 34:12:98:08:83:8d
[ 4232.670207] wlan0: send auth to 34:12:98:08:83:8d (try 1/3)
[ 4232.701514] wlan0: authenticated
[ 4232.703298] wlan0: associate with 34:12:98:08:83:8d (try 1/3)
[ 4232.705301] wlan0: RX ReassocResp from 34:12:98:08:83:8d (capab=0x1011 status=0 aid=3)
[ 4232.724226] wlan0: associated
[ 4232.726086] wlan0: Limiting TX power to 17 (17 - 0) dBm as advertised by 34:12:98:08:83:8d
[ 4241.461758] iwlwifi 0000:01:00.0: Unhandled alg: 0x71b
[ 4242.353281] iwlwifi 0000:01:00.0: Unhandled alg: 0x71b
[ 4242.353610] iwlwifi 0000:01:00.0: Unhandled alg: 0x71b
[ 4242.354436] iwlwifi 0000:01:00.0: Unhandled alg: 0x71b
[ 4242.434685] iwlwifi 0000:01:00.0: Unhandled alg: 0x71b
[ 4242.447902] iwlwifi 0000:01:00.0: Unhandled alg: 0x71b
[ 4242.447922] iwlwifi 0000:01:00.0: Unhandled alg: 0x71b
[ 4242.448034] iwlwifi 0000:01:00.0: Unhandled alg: 0x71b
[ 4242.528706] iwlwifi 0000:01:00.0: Unhandled alg: 0x71b
[ 4242.674306] iwlwifi 0000:01:00.0: Unhandled alg: 0x71b
[ 4309.327802] net_ratelimit: 6 callbacks suppressed
[ 4309.327809] iwlwifi 0000:01:00.0: Unhandled alg: 0x71b
[ 4344.167382] iwlwifi 0000:01:00.0: Unhandled alg: 0x71b
[ 4370.067817] audit: type=1130 audit(1609027412.701:151): pid=1 uid=0 auid=4294967295 ses=4294967295 msg=‘unit=NetworkManager-dispatcher comm=“systemd” exe=“/usr/lib/systemd/systemd” hostname=? addr=? terminal=? res=success’
[ 4380.106647] audit: type=1131 audit(1609027422.741:152): pid=1 uid=0 auid=4294967295 ses=4294967295 msg=‘unit=NetworkManager-dispatcher comm=“systemd” exe=“/usr/lib/systemd/systemd” hostname=? addr=? terminal=? res=success’
[ 4395.145932] iwlwifi 0000:01:00.0: Unhandled alg: 0x71b
[ 4395.146200] iwlwifi 0000:01:00.0: Unhandled alg: 0x71b
[ 4494.243436] wlan0: disconnect from AP 34:12:98:08:83:8d for new auth to 0c:51:01:e6:b4:d9
[ 4494.262262] wlan0: authenticate with 0c:51:01:e6:b4:d9
[ 4494.278258] wlan0: send auth to 0c:51:01:e6:b4:d9 (try 1/3)
[ 4494.309779] wlan0: authenticated
[ 4494.313284] wlan0: associate with 0c:51:01:e6:b4:d9 (try 1/3)
[ 4494.314833] wlan0: RX ReassocResp from 0c:51:01:e6:b4:d9 (capab=0x1011 status=0 aid=11)
[ 4494.331561] wlan0: associated
[ 4494.407754] wlan0: Limiting TX power to 17 (17 - 0) dBm as advertised by 0c:51:01:e6:b4:d9
[ 4497.538617] audit: type=1130 audit(1609027540.168:153): pid=1 uid=0 auid=4294967295 ses=4294967295 msg=‘unit=NetworkManager-dispatcher comm=“systemd” exe=“/usr/lib/systemd/systemd” hostname=? addr=? terminal=? res=success’
[ 4501.488535] audit: type=1100 audit(1609027544.118:154): pid=10747 uid=1000 auid=1000 ses=2 msg=‘op=PAM:unix_chkpwd acct=“jsauer” exe=“/usr/bin/unix_chkpwd” hostname=? addr=? terminal=? res=success’
[ 4508.108374] audit: type=1131 audit(1609027550.739:155): pid=1 uid=0 auid=4294967295 ses=4294967295 msg=‘unit=NetworkManager-dispatcher comm=“systemd” exe=“/usr/lib/systemd/systemd” hostname=? addr=? terminal=? res=success’
[ 4625.881039] wlan0: disconnect from AP 0c:51:01:e6:b4:d9 for new auth to 34:12:98:08:83:8d
[ 4625.897641] wlan0: authenticate with 34:12:98:08:83:8d
[ 4625.911964] wlan0: send auth to 34:12:98:08:83:8d (try 1/3)
[ 4625.942788] wlan0: authenticated
[ 4625.943189] wlan0: associate with 34:12:98:08:83:8d (try 1/3)
[ 4625.944966] wlan0: RX ReassocResp from 34:12:98:08:83:8d (capab=0x1011 status=0 aid=3)
[ 4625.963022] wlan0: associated
[ 4625.965598] wlan0: Limiting TX power to 17 (17 - 0) dBm as advertised by 34:12:98:08:83:8d
Have you try any of these from the Arch wiki?
https://wiki.archlinux.org/index.php/Network_configuration/Wireless#iwlwifi
necrobumped!
