So… Is it really Linux?
I thought it was Linux? Maybe it’s Linuxeos! It’s a high end version of Linux.
Edit: Linuxeos = Luxurious
I do not fully understand the suggestion.
The os-prober
has many ways of showing its power, again…
But if you don’t want to see so many linux words in a row, here’s what you can do about it.
Run the following command (if multi-booting, run in all EndeavourOS installs):
sudo pacman -S grub-tools eos-hooks grub
and run it last in the OS that controls booting.
Then reboot.
Personally, I like having Linux in my Linux… It’s staying the way it is here!
I get more power by having MORE Linux!
Here it is - my obligatory comment about rEFInd users not having to deal with these things…
Will this have any change if using rEFInd? I have triple boot with rEFInd but i use grubx64.efi to boot not the linuz-linux image.
Edit: Also i don’t have os-prober installed on each so that it doesn’t add entries to grub in each. I use rEFInd to load each which then boots from the grubx64.efi.
If you ditch package os-prober
, then the problems that grub
is often blamed for, will reduce radically.
In grub
, it is very easy to manually write menu entries for other installs in multi-boot environment.
Aren’t you manually writing about the same with rEFInd?
No, as far as I know. Note that I’m not using rEFInd…
Okay so i checked all of my installs on rEFInd and grub say’s EndeavourOS on Linux. I ran the command and reinstalled just to see and it doesn’t reinstall os-prober so I’m golden. I don’t have those issues. Thanks to @freebird54 for getting me onto rEFind! and Thank You @manuel for always checking into these things. rEFInd is awesome as far as I’m concerned.
Edit: BTW I like having EndeavourOS on my Linux!
EndeavourOS: 99% Arch, 500% Linux.
100% EndeavourOS 99.9% Arch 500% Linux
That would mean… that Arch is between 500.5% and 505% Linux…
I guess it all depends on how you swallow it. Some people like 99% ketchup and 1% fries!
Edit: It’s all Linux so i guess that’s why it’s Linux Linux!
we could use systemd-boot b.t.w.
I’d be happy to use something other than GRUB… if something else allowed booting into BTRFS snapshots, I find it extremely useful. Please correct me if I’m wrong.
Actually, not often. If I want some extra command line entry (nowatchdog, perhaps) then I add it - but otherwise workable is auto-generated. It is not all that unusual to use rEFInd to boot grub, actually - if grub is providing an extra service (like booting in to snapshots for instance). Of course, step one is ditching os-prober! As you mention, a huge percentage of grub errors are actually from that…
simple solution… use systemd-boot:
Perfectly good solution, for ONE distro on the box in question. In fact, I understand that rEFInd uses the same mechanisms (and looks a bit better, if that matters). I would also miss the ‘single user target’ boot mode for “those” times…
