should I add the entry then?
no it means that this is not supported i think question is how does this entry land in your config?
IDK, got desperate so I ran
sudo locale-gen en_TT.UTF-8 en_BM.UTF-8
Generating locales...
ar_TN.UTF-8... done
ar_TN.ISO-8859-6... done
en_US.UTF-8... done
en_GB.UTF-8... done
en_US.UTF-8... done
Generation complete.
but I got this message on Steam pv-locale-gen: Warning: en_BM.UTF-8 was generated but does not appear to work!
which pv-locale-gen ?
this is not from the target OS something steam uses may proton?
which pv-locale-gen
which: no pv-locale-gen in (/home/bargo/.cargo/bin:/usr/local/sbin:/usr/local/bin:/usr/bin:/opt/cuda/bin:/opt/cuda/nsight_compute:/opt/cuda/nsight_systems/bin:/usr/lib/jvm/default/bin:/usr/bin/site_perl:/usr/bin/vendor_perl:/usr/bin/core_perl:/usr/lib/rustup/bin:/home/bargo/.local/bin:/home/bargo/.local/bin)
like I said, my brother uses the exact same OS and distro, EndeavourOS on nearly the same hardware, however he has not the problem and I have, the only significant difference is that I customized many thing and he did not
i bet something in steam that you setup is causing this not OS ..
I will post this problem in the Steam community but FYI while this problem affects only Steam and the Steam games, Gamemode is also affected in all platforms like HGL
i bet on steam they could know better what would causing this ..
Can you link to your report? i could may add info incase
Yes, of course, here you go
