Issues with forced V-Sync in Minecraft (Wayland+x11)
Hello! I’ve been daily driving EOS for about 6 months now, and I finally decided to try and play minecraft. As we all know, it tends to drop frames when running with V-Sync on the monitor.
However, disabling it in the game settings causes it to disable V-Sync for windowed mode, but not fullscreen.
Strangely, running it in the background (unfocused fullscreen) has it with V-Sync disabled.
So I tried working around this by disabling the window frame in KDE’s settings, but that caused the game to re-enable V-sync, even while (now borderless) windowed.
Screenshot_20230726_131128
Fullscreen
Screenshot_20230726_131247
Windowed Maximized
inxi output
http://ix.io/4Bzk
If you can’t be bothered to look at the inxi - I’m running in KDE wayland with NVIDIA’s proprietary 535 driver.
Any ideas on what can be done?
UPDATE
Tried using x11, but it has the same issues. Damn, never woulda thought it wasn’t a NVIDIA wayland thing lmao
UPDATE 2
JVM Args such as
“-Dminecraft.disableVsync=true”
or
“-Dsun.java2d.d3d=false”
seemed to have no effect on the issue
