I have been attempting to create a dual boot between windows 10 and endeavouros artemis. Both tutorials and general experimentations have been attempted. Neither have proven remotely successful.
I cannot find any tutorials relating to the artemis release and I presume something has changed significantly enough to alter the way that a dual boot must be set up.
Nope, as far as I know nothing has changed significantly or at all regarding the boot process.
What tutorials have you followed
Do you have a legacy boot or UEFI?
You need to properly describe the issue and the steps you’ve taken so that people know what the issue is and attempt to reproduce it.
Can you start first by sending us hardware logs from the live ISO
There are various issues.
Having tried every combination of anything I could find on the topic nothing worked in the slightest.
There was always one os that refused to boot, or on one occasion it corrupted both and I had to wipe the drive.
I have asked here in a hope to avoid doing so again
Model: ATA WDC WD5000AAVS-0 (scsi)
Disk /dev/sda: 500GB
Sector size (logical/physical): 512B/512B
Partition Table: gpt
Disk Flags:
Number Start End Size File system Name Flags
1 1049kB 106MB 105MB fat32 EFI system partition boot, esp
2 106MB 123MB 16.8MB Microsoft reserved partition msftres
3 123MB 500GB 499GB ntfs Basic data partition msftdata
4 500GB 500GB 534MB ntfs hidden, diag
Disk /dev/sdb: 500GB
Disk Flags:
1 1049kB 500GB 500GB Basic data partition msftdata
Model: ATA Hitachi HTS54757 (scsi)
Disk /dev/sdc: 750GB
Sector size (logical/physical): 512B/4096B
Partition Table: msdos
Disk Flags:
Number Start End Size Type File system Flags
Model: Generic Flash Disk (scsi)
Disk /dev/sdd: 2045MB
Disk Flags:
2 1833MB 1940MB 107MB primary fat16 esp
Since your Windows (on /dev/sda) is installed in UEFI mode, you would need to install EnOS in the same mode as well. For that you should be booting up your live USB in UEFI.
Go into the firmware settings (BIOS/UEFI settings) and disable Legacy and/or CSM boot mode.
Boot up your live usb and try installing again.
In case you have any doubts/questions, please feel free to post them here.
