Issue with pacman repository "community"
Recently I install EndeavourOS. Then, when I tried download some packages from community I every time get error.
Example of error:
error: failed retrieving file 'iotop-0.6-9-any.pkg.tar.zst' from de.freedif.org : The requested URL returned error: 404
warning: failed to retrieve some files
error: failed to commit transaction (failed to retrieve some files)
p.s. reflector in welcome screen
Run
sudo pacman -Syyu
to fully update your system first. Then try to install the package you want.
If you still have issues, launch the welcome app and refresh your mirrors.
Then try again.
This usually means you are trying to install a package without updating the system first.
Try using:
sudo pacman -Syu iotop
You can try refreshing your mirrors with reflector
https://wiki.archlinux.org/title/reflector
Glad you found the solution which you will be using again and again.
Welcome to the good ship :enos: and enjoy!
