Hi,
I’m trying to switch all my current applications to flatpaks.
I’ve started to switch starting with Spotify but I can’t seem to login sue to fact it wont open a tab on my browser.
Hi,
No sure why you’ve chosen flatpaks, but have you heard about Distrobox?
https://wiki.archlinux.org/title/Distrobox
tried launching it from the terminal got this error
/app/bin/spotify: line 45: Xlib.xauth:: command not found
Does anyone know a fix for this on wayland?
See if this thread solve your issue:
https://www.reddit.com/r/flatpak/comments/13p7ldf/spotify_wants_to_open_a_browser_tab_but_wont/
I also recommending this Native Spotity Client: https://flathub.org/apps/dev.alextren.Spot (if you running Gnome).
Pretty much knows were the problem is but not sure how to fix it
flatpak run --command=xdg-open com.spotify.Client https://www.google.com
Failed to call portal: GDBus.Error:org.freedesktop.DBus.Error.UnknownMethod: No such interface ?org.freedesktop.portal.OpenURI? on object at path /org/freedesktop/portal/desktop
You could try asking for help here maybe or seeing if there is an answer
