Hi,
If I click on the eos-update-notifier notification when it appears, nothing happens. The notification only disappears and no update is performed.
Did I miss something ? Isn’t a terminal windows supposed to appear ?
I think a notifier pop up is a notifier not a start button.
Edit:
What is it?
EndeavourOS Update Notifier, as the name suggests, is a notifier for software updates. As many other notifiers, it can also start the update process.
Seems my language barrier is to big
Welcome @Fredebec,
You need to use the welcome app to update or more. If You closed it, just tape in Terminal :
eos-welcome
then update with the good button…
You probably want to configure it differently.
Hi @Fredebec. You can run eos-update-notifier
in a terminal to see what might be happening. I’m using Gnome and gnome-terminal
and it is currently working correctly.
but default setting is now set to notify only so it will not include a way to update directly per default… it only show if updates are available.
cat /etc/eos-update-notifier.conf
### eos-update-notifier configuration file
## Check also updates from AUR:
CheckAurUpdates=yes # yes or no
## Check also Arch news for you:
CheckArchNewsForYou=yes # yes or no
## Alternative programs for showing the Arch news. Select one.
## Note: 'arch-news-for-you' uses an ad hoc way to determine if the news are
## relevant to your machine. This mostly works well, but not always.
## The 'eos-arch-news' shows news based on the date and shows only news
## that are not yet shown.
## This option was added in eos-update-notifier version 0.9-1.
ArchNewsProg=eos-arch-news # values: 'eos-arch-news' or 'arch-news-for-you'
## Prefer tray notification or small window for nofitying about updates?
## NOTE: if clicking the tray notification icon launches also the next panel item,
## a workaround is either to
## - re-organize panel's notification area icons so that 'Yad' is not the first (uppermost), or
## - add an empty launcher right next to the tray notification icon.
ShowHowAboutUpdates=notify # value: 'notify', 'notify+tray', 'tray', or 'window'
## What info to show about pending updates ("number of updates" or "package names");
## applies only when 'ShowHowAboutUpdates' is set to 'window':
ShowWhatAboutUpdates=number # values: 'number' or 'packages'
you can change the line:
to:
ShowHowAboutUpdates=notify+tray # value: 'notify', 'notify+tray', 'tray', or 'window'
so you get notification + a tray icon to click it to perform updates.
it is a update notifier also mainly but includes some very nice features!
Thank you all for your answers.
@manuel, thanks for the link. I see that I can modify “/etc/eos-update-notifier.conf” to change the behavior.
The system is up-to date now, but I will play with it later to test the options.
Edit: @joekamprad, thanks for the detailed solution !
Right on. I totally forgot the default is to just notify!
