Recently had to re-install my Endeavour, and having issues getting the system to talk to my Bluetooth speakers. It sees them, but simply won’t connect to them telling me “br-connection-unknown”. I’m not able to determine the issue, I’ve tried switching from pulseaudio to pipewire no change.
welcome at the forum
Bluetooth is not enabled per default on EndeavourOS, so user can decide to start it only if needed to enable it to be active over reboots.
[chris@endeavour ~]$ systemctl --user status pipewire.socket
● pipewire.socket - Multimedia System
Loaded: loaded (/usr/lib/systemd/user/pipewire.socket; enabled; vendor preset: enabled)
Active: active (running) since Fri 2021-11-26 03:36:47 CST; 1h 9min ago
Triggers: ● pipewire.service
Listen: /run/user/1000/pipewire-0 (Stream)
CGroup: /user.slice/user-1000.slice/user@1000.service/app.slice/pipewire.socket
Nov 26 03:36:47 endeavour systemd[1419]: Listening on Multimedia System.
[chris@endeavour ~]$ systemctl status bluetooth
● bluetooth.service - Bluetooth service
Loaded: loaded (/usr/lib/systemd/system/bluetooth.service; enabled; vendor preset: disabled)
Active: active (running) since Fri 2021-11-26 03:36:29 CST; 1h 10min ago
Docs: man:bluetoothd(8)
Main PID: 1312 (bluetoothd)
Status: “Running”
Tasks: 1 (limit: 57673)
Memory: 2.3M
CPU: 23ms
CGroup: /system.slice/bluetooth.service
└─1312 /usr/lib/bluetooth/bluetoothd
Nov 26 03:36:57 endeavour bluetoothd[1312]: profiles/audio/avdtp.c:avdtp_connect_cb() connect to EC:81:93:E9:D1:FC: Permission denied (13)
Nov 26 03:37:00 endeavour bluetoothd[1312]: profiles/audio/avdtp.c:avdtp_connect_cb() connect to EC:81:93:E9:D1:FC: Too many levels of symbolic links (40)
Nov 26 03:38:06 endeavour bluetoothd[1312]: profiles/audio/avdtp.c:avdtp_connect_cb() connect to EC:81:93:E9:D1:FC: Permission denied (13)
Nov 26 03:38:08 endeavour bluetoothd[1312]: profiles/audio/avdtp.c:avdtp_connect_cb() connect to EC:81:93:E9:D1:FC: Too many levels of symbolic links (40)
Nov 26 03:50:07 endeavour bluetoothd[1312]: profiles/audio/avdtp.c:avdtp_connect_cb() connect to EC:81:93:E9:D1:FC: Permission denied (13)
Nov 26 03:50:10 endeavour bluetoothd[1312]: profiles/audio/avdtp.c:avdtp_connect_cb() connect to EC:81:93:E9:D1:FC: Too many levels of symbolic links (40)
Nov 26 04:44:01 endeavour bluetoothd[1312]: profiles/audio/avdtp.c:avdtp_connect_cb() connect to EC:81:93:E9:D1:FC: Permission denied (13)
Nov 26 04:44:04 endeavour bluetoothd[1312]: profiles/audio/avdtp.c:avdtp_connect_cb() connect to EC:81:93:E9:D1:FC: Too many levels of symbolic links (40)
Nov 26 04:44:44 endeavour bluetoothd[1312]: profiles/audio/avdtp.c:avdtp_connect_cb() connect to EC:81:93:E9:D1:FC: Permission denied (13)
Nov 26 04:44:47 endeavour bluetoothd[1312]: profiles/audio/avdtp.c:avdtp_connect_cb() connect to EC:81:93:E9:D1:FC: Too many levels of symbolic links (40)
As to recognize the device BT uses keys… and if you are dualbooting and using the device in different OS the keys changes what is resulting in not being able to connect
