Issue on eos-boot-required
The last update has modified the modules eos-bash-shared, eos-rankmirrors and welcome.
At the end it has been created the symlink:
/etc/systemd/system/timers.target.wants/eos-reboot-required.timer → /usr/lib/systemd/system/eos-reboot-required.timer
Now when I boot the system on the log there are some warnings:
set 14 09:54:16 ACE systemd[1]: eos-reboot-required.timer: Deactivated successfully.
set 14 09:54:17 ACE eos-reboot-required3[599]: /usr/bin/id: "": no such user
set 14 09:54:17 ACE eos-reboot-required3[600]: su: user  does not exist or the user entry does not contain all the required fields
set 14 09:54:17 ACE systemd[1]: eos-reboot-required.service: Main process exited, code=exited, status=1/FAILURE
set 14 09:54:17 ACE systemd[1]: eos-reboot-required.service: Failed with result 'exit-code'.
and above all when it is mandatory to reboot the system I don’t receive the eos notification.
It seems an issue on the module.
The solution found in:
Bug reports
