So.. I’m a bit new to endeavouros and all, and things have been going pretty good when it comes to the whole functionality of the operating system, though i decided to try and create a new profile in the os for me to do things related to my projects (so i don’t have any of the normal distractions that my normal profile has), but all of the apps currently in my normal profile are in there, and if i try to remove them they also get removed from my normal profile. I’m not sure if that’s normal behavior..? I mean, in a few other operating systems that i used it wasn’t.
Basically what i’m trying to ask: is there a way for apps to not be shared through different profiles in the os?
Go through your applications and make a list of the ones you want in only user profile or the other
Go to flathub.com and verify that all the applications you need are available on flathub
If they are, uninstall all the applications using pacman or yay
Login to the first user account, and install the applications for that user with the flatpak command. It would be something like this: flatpak --user install application. Replace application with the name of the application you want to install.
Then login to the second user and do the same for those applications.
Arent Flatpak, Snap and AppImage installed by default in the users $HOME directory and not in the /usr or /opt directory like packages/applications from the official repos are?
And since they are installed in the $HOME directory they are not accessible to other users of Linux?
@48a48a48a48a are you referring to the behavior that is exhibited by Microsoft Teams and possibly Google Chrome too on Windows systems where they are installed in the %USERPROFILE% directory and are not accessible by others users?
There are user and system Flatpaks, when using “flatpak --user” they will be installed for that user only and if you don’t use the flag “–user” then they will be installed as system flatpaks so system wide.
Sorry for responding so late, had to do some things.. anyway, i’ve read everything you all said, and i uninstalled every single application installed in my system (that i want to separate), though when i run flatpak --user install application for any application i always get the same notification: error:No remote refs found for ‘application’. And from what i saw that only happens when i put --user in the line.. i’m not sure if there is any difference between the user version and the system one (there probably is), but i think it should work..? I saw on flathub at least that it should.
Nvm, i’m just so stupid.. i forgot that flathub acts on the system side of things, so i just needed to make a “new” remote flathub that only acts in the user, basically all i did was just execute the flatpak remote-add --if-not-exists --user flathub ``https://flathub.org/repo/flathub.flatpakrepo , which contains --userand all.. anyway, thank you all so much for helping me!!
