The bugid: Cannot read /root/.parallel/tmp/sshlogin/arkeo/linelen
The command line being run
The files being read (put the files on a webserver if they are big)
If you get the error on smaller/fewer files, please include those instead.
(4/4) Updating the desktop file MIME type cache…
I understand that the error is caused by the /root/.parallel/tmp/sshlogin/arkeo/linelen which isn’t readable, although I can see it with sudo ls -als /root/.parallel/tmp/sshlogin/arkeo.
total 8
4 drwxr-xr-x 2 root root 4096 Oct 5 11:22 .
4 drwxr-xr-x 3 root root 4096 Oct 5 11:22 ..
0 -rw-r--r-- 1 root root 0 Oct 5 11:22 linelen
Is there a simple way to fix that error?
For example, if I edit that file to contain the console line length, would that be sufficient to avoid the error?
Is putting 134 sufficient to set the line length?
I know I can report the bug. I was wondering if a workaround could be as simple as editing a file. I know that wouldn’t fix the bug, but I wouldn’t see that error message, at least.
I checked with yay -Qi parallel why it was installed.
Version : 20221022-1
Description : A shell tool for executing jobs in parallel
Architecture : any
URL : https://www.gnu.org/software/parallel/
Licenses : GPL3
Groups : None
Provides : None
Depends On : perl procps
Optional Deps : None
Required By : rebuild-detector
Optional For : None
Conflicts With : None
Replaces : None
Installed Size : 817.23 KiB
Packager : George Rawlinson <grawlinson@archlinux.org>
Build Date : Sun 23 Oct 2022 12:36:06 AM CEST
Install Date : Tue 01 Nov 2022 09:01:10 PM CET
Install Reason : Installed as a dependency for another package
Install Script : No
Validated By : Signature
yay -Qi rebuild-detector got me the following.
Version : 4.4.1-2
Description : Detects which packages need to be rebuilt
Architecture : any
URL : https://github.com/maximbaz/rebuild-detector
Licenses : ISC
Groups : None
Provides : None
Depends On : parallel pacutils pacman-contrib
Required By : None
Optional For : None
Replaces : None
Installed Size : 6.12 KiB
Packager : Maxim Baz <maximbaz@archlinux.org>
Build Date : Fri 25 Feb 2022 10:14:11 AM CET
Install Date : Mon 03 Oct 2022 07:12:02 PM CEST
Install Reason : Explicitly installed
Install Script : No
So, it was a dependency of rebuild-detector I installed without understanding it runs every time I update packages.
I started getting that error three/four days ago; before, I was getting only a message about pacman which was checking which Perl modules had to be updated.
I haven’t installed anything new, these days. I just keep updating EOS with yay -Syu.
Your previous reply helped me to understand it’s not an error caused by pacman but by a tool that “hooks” into pacman. Without that tool, att least, I can run pacman -Syu or yay -Syu without seeing that message error.
I will reinstall rebuild-detector later.
