Deepin DE is installed. I recently encountered the following error while updating the qcef AUR package https://aur.archlinux.org/packages/qcef “no more disk space”. For this reason, I ask if this package is absolutely necessary for Deepin to work, or can it be safely removed without consequences?
Looking at the dependencies here:https://aur.archlinux.org/packages/qcef and here:https://aur.archlinux.org/packages/nss-hg/ I wouldn’t. Although nss ( nss-hg ) are two of them and nss-hg is has dependency on p11-kit have you done the manual intervention here? https://www.archlinux.org/news/nss3511-1-and-lib32-nss3511-1-updates-require-manual-intervention/
everything from aur is not neccesary for the repo packages unless you take other aur packages that needed always tricky
The problem is solved. The above mentioned package has been updated with yay instead of pamac.
