Is it safe to swap light-slick-greeter with lightdm-gtk-greeter on /etc/lightdm/lightdm.conf
I customized lightdm-gtk-greeter’s settings for my login screen but the changes won’t apply themselves because light-slick-greeter is enabled… Is it safe to change?
Related to:
Yes, just change the greeter name to lightdm-gtk-greeter in lightdm configuration file.
Can I remove lightdm-slick-greeter now?
Up to you.
I mean, is it needed or not? I don’t use it but I’m unsure whether it’s used by Endeavour or not…
It was used, but you changed it. So it is not needed.
