Is it possible to limit CPU, so the Fan can be disabled?
Hello,
a few Month ago i bought me a used Thinkpad T14 G1 with AMD 4650U CPU. Overall i like the machine, everything works fine using EndeavourOS with KDE Plasma 6.
But it could be a little bit more silent, though. I’m using the Laptop only for easy tasks, like browsing internet, watching videos and doing some light office stuff.
So i ask myself, maybe it is possible to limit the cpu to a level, that the fan could be disabled?
I wouldn’t recommend disabling the fan altogether but you could throttle it down to the point where it wouldn’t come on very easily.
Have a look at cpupower:
https://wiki.archlinux.org/title/CPU_frequency_scaling#cpupower
https://wiki.archlinux.org/title/CPU_frequency_scaling#Setting_maximum_and_minimum_frequencies
You would need then disable/mask power-profiles-daemon which is used by default.
yes, that would be great. some guys on reddit recommend TLP. Is that the slickest way to do it?
ok, thanks, i’ll look into it.
