Is it ok to uninstall eos-settings-plasma completely?
Or rather, does uninstalling it break anything else?
I love EndeavourOS, but not so much the EOS theme, sorry. Neither dark, nor purple …
The way you know if it breaks anything else is by running pacman -Qi pkgname or by attempting to uninstall said package, as Pacman will warn you that it breaks a dependecy.
pacman -Qi eos-settings-plasma
Check where it says, “Required By” and/or “Optional For”.
If it shows a package you need, then don’t uninstall it. If it doesn’t show a package you need, then you are free to uninstall it with no worries.
You can check things this way with any package.
Lastly, it’s a theme and some additional settings.
You don’t need to remove it to use another theme or change the settings.
thx @ddnn , that looks god:
[darius@eos-pc ~]$ LC_ALL=C pacman -Qi eos-settings-plasma
Version         : 1.7-1
Description     : Plasma settings and theme for EndeavourOS
Architecture    : any
URL             : https://github.com/endeavouros-team/eos-settings-plasma
Licenses        : GPL3
Groups          : None
Provides        : None
Depends On      : plasma-workspace  endeavouros-theming
Optional Deps   : None
Required By     : None
Optional For    : None
Conflicts With  : None
Replaces        : None
Installed Size  : 666.17 KiB
Packager        : manuel <manuel@endeavouros.com>
Build Date      : Tue Mar 26 20:07:30 2024
Install Date    : Fri Nov 1 15:26:31 2024
Install Reason  : Explicitly installed
Install Script  : No
Validated By    : SHA-256 Sum  Signature
Don’t mean to hijack the thread here, but I’ve been messing around with AI voice narration/generation. I thought I’d use the solution here and attempt a narration of the solution…
I don’t sound like that, though. :sweat_smile:
Well, I didn’t think so! :joy: I just tried to modulate a typical “narration” type voice.
