Hi all,
My Intel E810XXV 25G nic does not re-establish a connection once resuming from suspend (sleep).
$ lspci -vv
11:00.0 Ethernet controller: Intel Corporation Ethernet Controller E810-XXV for SFP (rev 02)
Subsystem: Intel Corporation Ethernet Network Adapter E810-XXV-2
Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0, Cache Line Size: 64 bytes
Interrupt: pin A routed to IRQ 24
IOMMU group: 21
Region 0: Memory at 850000000 (64-bit, prefetchable) [size=32M]
Region 3: Memory at 856000000 (64-bit, prefetchable) [size=64K]
Expansion ROM at b0200000 [disabled] [size=1M]
Capabilities: <access denied>
Kernel driver in use: ice
Kernel modules: ice
the link is shown as state: down
$ inxi -Fxz
Device-3: Intel Ethernet E810-XXV for SFP driver: ice v: kernel port: N/A
bus-ID: 11:00.0
IF: enp17s0f0np0 state: down mac: <filter>
Device-4: Intel Ethernet E810-XXV for SFP driver: ice v: kernel port: N/A
bus-ID: 11:00.1
IF: enp17s0f1np1 state: down mac: <filter>
also on ethtool
, Link detected: no
$ sudo ethtool enp17s0f0np0
Settings for enp17s0f0np0:
Supported ports: [ FIBRE ]
Supported link modes: 1000baseT/Full
10000baseT/Full
25000baseCR/Full
25000baseSR/Full
1000baseX/Full
10000baseSR/Full
10000baseLR/Full
Supported pause frame use: Symmetric
Supports auto-negotiation: No
Supported FEC modes: None
Advertised link modes: 25000baseSR/Full
10000baseSR/Full
Advertised pause frame use: No
Advertised auto-negotiation: No
Advertised FEC modes: None
Speed: 10000Mb/s
Duplex: Full
Auto-negotiation: off
Port: FIBRE
PHYAD: 0
Transceiver: internal
Supports Wake-on: d
Wake-on: d
Current message level: 0x00000007 (7)
drv probe link
Link detected: no
One resumed from sleep, I can physically see on the nic that the link and activity lights are blinking. On the switch management side I can also see the link to client is established. So it seems like a software/driver issue to me.
A system reboot re-establishes the link.
