Instant resume after hibernation
Hello,
my laptop is always directly resuming, when i want to go to hibernation mode. That is especially bad in a low-battery situation, where all unsaved work could be lost.
swap is on:
[marcel@ymir ~]$ swapon --show
NAME      TYPE SIZE USED PRIO
/swapfile file  31G   0B   -2
journal of the time between starting hibernation and resume:
Mär 24 12:24:55 ymir systemd-logind[1120]: The system will hibernate now!
Mär 24 12:24:55 ymir NetworkManager[1130]: <info>  [1711279495.1893] manager: sleep: sleep requested (sleeping: no  enabled: yes)
Mär 24 12:24:55 ymir NetworkManager[1130]: <info>  [1711279495.1894] device (enp2s0f0): state change: unavailable -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
Mär 24 12:24:55 ymir polkitd[1132]: Unregistered Authentication Agent for unix-process:unknown (system bus name :1.242, object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale de_DE.UTF-8) (disconnected from bus)
Mär 24 12:24:55 ymir NetworkManager[1130]: <info>  [1711279495.2001] device (p2p-dev-wlan0): state change: disconnected -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
Mär 24 12:24:55 ymir NetworkManager[1130]: <info>  [1711279495.2006] manager: NetworkManager state is now ASLEEP
Mär 24 12:24:55 ymir NetworkManager[1130]: <info>  [1711279495.2013] device (wlan0): state change: activated -> deactivating (reason 'sleeping', sys-iface-state: 'managed')
Mär 24 12:24:55 ymir systemd[1]: Starting Network Manager Script Dispatcher Service...
Mär 24 12:24:55 ymir systemd[1]: Started Network Manager Script Dispatcher Service.
Mär 24 12:24:55 ymir kernel: wlan0: deauthenticating from e0:28:6d:25:60:42 by local choice (Reason: 3=DEAUTH_LEAVING)
Mär 24 12:24:55 ymir kded6[1487]: org.kde.plasma.nm.kded: Unhandled active connection state change:  3
Mär 24 12:24:55 ymir wpa_supplicant[1238]: wlan0: CTRL-EVENT-DISCONNECTED bssid=e0:28:6d:25:60:42 reason=3 locally_generated=1
Mär 24 12:24:55 ymir wpa_supplicant[1238]: wlan0: CTRL-EVENT-DSCP-POLICY clear_all
Mär 24 12:24:55 ymir NetworkManager[1130]: <info>  [1711279495.4867] device (wlan0): supplicant interface state: completed -> disconnected
Mär 24 12:24:55 ymir NetworkManager[1130]: <info>  [1711279495.4870] device (wlan0): state change: deactivating -> disconnected (reason 'sleeping', sys-iface-state: 'managed')
Mär 24 12:24:55 ymir avahi-daemon[1107]: Withdrawing address record for 2a01:c23:71a0:a200:aed0:84fa:a53c:7a0f on wlan0.
Mär 24 12:24:55 ymir avahi-daemon[1107]: Leaving mDNS multicast group on interface wlan0.IPv6 with address 2a01:c23:71a0:a200:aed0:84fa:a53c:7a0f.
Mär 24 12:24:55 ymir NetworkManager[1130]: <info>  [1711279495.4876] dhcp4 (wlan0): canceled DHCP transaction
Mär 24 12:24:55 ymir avahi-daemon[1107]: Joining mDNS multicast group on interface wlan0.IPv6 with address fe80::7fab:69bd:643f:785.
Mär 24 12:24:55 ymir NetworkManager[1130]: <info>  [1711279495.4876] dhcp4 (wlan0): activation: beginning transaction (timeout in 45 seconds)
Mär 24 12:24:55 ymir avahi-daemon[1107]: Registering new address record for fe80::7fab:69bd:643f:785 on wlan0.*.
Mär 24 12:24:55 ymir NetworkManager[1130]: <info>  [1711279495.4876] dhcp4 (wlan0): state changed no lease
Mär 24 12:24:55 ymir avahi-daemon[1107]: Withdrawing address record for fe80::7fab:69bd:643f:785 on wlan0.
Mär 24 12:24:55 ymir NetworkManager[1130]: <info>  [1711279495.4878] dhcp6 (wlan0): canceled DHCP transaction
Mär 24 12:24:55 ymir avahi-daemon[1107]: Leaving mDNS multicast group on interface wlan0.IPv6 with address fe80::7fab:69bd:643f:785.
Mär 24 12:24:55 ymir NetworkManager[1130]: <info>  [1711279495.4878] dhcp6 (wlan0): activation: beginning transaction (timeout in 45 seconds)
Mär 24 12:24:55 ymir avahi-daemon[1107]: Interface wlan0.IPv6 no longer relevant for mDNS.
Mär 24 12:24:55 ymir NetworkManager[1130]: <info>  [1711279495.4878] dhcp6 (wlan0): state changed no lease
Mär 24 12:24:55 ymir avahi-daemon[1107]: Interface wlan0.IPv4 no longer relevant for mDNS.
Mär 24 12:24:55 ymir avahi-daemon[1107]: Leaving mDNS multicast group on interface wlan0.IPv4 with address 192.168.178.41.
Mär 24 12:24:55 ymir avahi-daemon[1107]: Withdrawing address record for 192.168.178.41 on wlan0.
Mär 24 12:24:55 ymir NetworkManager[1130]: <info>  [1711279495.5341] device (wlan0): set-hw-addr: set MAC address to A6:25:3C:18:86:98 (scanning)
Mär 24 12:24:55 ymir avahi-daemon[1107]: Joining mDNS multicast group on interface wlan0.IPv4 with address 192.168.178.41.
Mär 24 12:24:55 ymir avahi-daemon[1107]: New relevant interface wlan0.IPv4 for mDNS.
Mär 24 12:24:55 ymir avahi-daemon[1107]: Registering new address record for 192.168.178.41 on wlan0.IPv4.
Mär 24 12:24:55 ymir NetworkManager[1130]: <info>  [1711279495.6888] device (wlan0): supplicant interface state: disconnected -> interface_disabled
Mär 24 12:24:55 ymir NetworkManager[1130]: <info>  [1711279495.6889] device (wlan0): supplicant interface state: interface_disabled -> disconnected
Mär 24 12:24:55 ymir NetworkManager[1130]: <info>  [1711279495.6921] device (wlan0): state change: disconnected -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
Mär 24 12:24:55 ymir NetworkManager[1130]: <info>  [1711279495.9335] device (wlan0): set-hw-addr: reset MAC address to 44:AF:28:3B:7B:C1 (unmanage)
Mär 24 12:24:55 ymir wpa_supplicant[1238]: p2p-dev-wlan0: CTRL-EVENT-DSCP-POLICY clear_all
Mär 24 12:24:55 ymir wpa_supplicant[1238]: nl80211: deinit ifname=p2p-dev-wlan0 disabled_11b_rates=0
Mär 24 12:24:55 ymir systemd[1]: Reached target Sleep.
Mär 24 12:24:55 ymir systemd[1]: Starting System Hibernate...
Mär 24 12:24:55 ymir systemd-sleep[36504]: Performing sleep operation 'hibernate'...
Mär 24 12:24:55 ymir kernel: PM: hibernation: hibernation entry
Mär 24 12:25:01 ymir kernel: Filesystems sync: 0.004 seconds
Mär 24 12:25:01 ymir kernel: Freezing user space processes
Mär 24 12:25:01 ymir kernel: Freezing user space processes completed (elapsed 0.031 seconds)
Mär 24 12:25:01 ymir kernel: OOM killer disabled.
Mär 24 12:25:01 ymir kernel: PM: hibernation: Marking nosave pages: [mem 0x00000000-0x00000fff]
Mär 24 12:25:01 ymir kernel: PM: hibernation: Marking nosave pages: [mem 0x0009f000-0x000fffff]
Mär 24 12:25:01 ymir kernel: PM: hibernation: Marking nosave pages: [mem 0x09c00000-0x09d00fff]
Mär 24 12:25:01 ymir kernel: PM: hibernation: Marking nosave pages: [mem 0x09f00000-0x09f0ffff]
Mär 24 12:25:01 ymir kernel: PM: hibernation: Marking nosave pages: [mem 0xa2bf2000-0xa2bf2fff]
Mär 24 12:25:01 ymir kernel: PM: hibernation: Marking nosave pages: [mem 0xa2bff000-0xa2c00fff]
Mär 24 12:25:01 ymir kernel: PM: hibernation: Marking nosave pages: [mem 0xa2c11000-0xa2c11fff]
Mär 24 12:25:01 ymir kernel: PM: hibernation: Marking nosave pages: [mem 0xb97c1000-0xb9851fff]
Mär 24 12:25:01 ymir kernel: PM: hibernation: Marking nosave pages: [mem 0xbd9de000-0xcc3fdfff]
Mär 24 12:25:01 ymir kernel: PM: hibernation: Marking nosave pages: [mem 0xce000000-0xffffffff]
Mär 24 12:25:01 ymir kernel: PM: hibernation: Basic memory bitmaps created
Mär 24 12:25:01 ymir kernel: PM: hibernation: Preallocating image memory
Mär 24 12:25:01 ymir kernel: PM: hibernation: Allocated 1715532 pages for snapshot
Mär 24 12:25:01 ymir kernel: PM: hibernation: Allocated 6862128 kbytes in 2.66 seconds (2579.74 MB/s)
Mär 24 12:25:01 ymir kernel: Freezing remaining freezable tasks
Mär 24 12:25:01 ymir kernel: Freezing remaining freezable tasks completed (elapsed 0.001 seconds)
Mär 24 12:25:01 ymir kernel: printk: Suspending console(s) (use no_console_suspend to debug)
Mär 24 12:25:01 ymir kernel: amdgpu 0000:06:00.0: amdgpu: MODE2 reset
Mär 24 12:25:01 ymir kernel: ACPI: EC: interrupt blocked
Mär 24 12:25:01 ymir kernel: ACPI: PM: Preparing to enter system sleep state S4
Mär 24 12:25:01 ymir kernel: ACPI: EC: event blocked
Mär 24 12:25:01 ymir kernel: ACPI: EC: EC stopped
Mär 24 12:25:01 ymir kernel: ACPI: PM: Saving platform NVS memory
Mär 24 12:25:01 ymir kernel: Disabling non-boot CPUs ...
Mär 24 12:25:01 ymir kernel: Wakeup pending. Abort CPU freeze
Mär 24 12:25:01 ymir kernel: Non-boot CPUs are not disabled
Mär 24 12:25:01 ymir kernel: ACPI: EC: EC started
Mär 24 12:25:01 ymir kernel: ACPI: PM: Waking up from system sleep state S4
Mär 24 12:25:01 ymir kernel: ACPI: EC: interrupt unblocked
Mär 24 12:25:01 ymir kernel: ACPI: EC: event unblocked
Mär 24 12:25:01 ymir kernel: usb usb1: root hub lost power or was reset
Mär 24 12:25:01 ymir kernel: usb usb2: root hub lost power or was reset
Mär 24 12:25:01 ymir kernel: usb usb4: root hub lost power or was reset
Mär 24 12:25:01 ymir kernel: usb usb3: root hub lost power or was reset
Mär 24 12:25:01 ymir kernel: usb usb5: root hub lost power or was reset
Mär 24 12:25:01 ymir kernel: xhci_hcd 0000:05:00.0: Zeroing 64bit base registers, expecting fault
Mär 24 12:25:01 ymir kernel: usb usb6: root hub lost power or was reset
Mär 24 12:25:01 ymir kernel: usb usb7: root hub lost power or was reset
Mär 24 12:25:01 ymir kernel: pci 0000:00:00.2: can't derive routing for PCI INT A
Mär 24 12:25:01 ymir kernel: pci 0000:00:00.2: PCI INT A: no GSI
Mär 24 12:25:01 ymir kernel: [drm] PCIE GART of 1024M enabled.
Mär 24 12:25:01 ymir kernel: [drm] PTB located at 0x000000F41FC00000
Mär 24 12:25:01 ymir kernel: [drm] PSP is resuming...
Mär 24 12:25:01 ymir kernel: usb 4-3: reset full-speed USB device number 2 using xhci_hcd
Mär 24 12:25:01 ymir kernel: usb 2-2: reset high-speed USB device number 2 using xhci_hcd
Mär 24 12:25:01 ymir kernel: nvme nvme0: 16/0/0 default/read/poll queues
Mär 24 12:25:01 ymir kernel: [drm] reserve 0x400000 from 0xf41f800000 for PSP TMR
Mär 24 12:25:01 ymir kernel: amdgpu 0000:06:00.0: amdgpu: RAS: optional ras ta ucode is not available
Mär 24 12:25:01 ymir kernel: amdgpu 0000:06:00.0: amdgpu: RAP: optional rap ta ucode is not available
Mär 24 12:25:01 ymir kernel: amdgpu 0000:06:00.0: amdgpu: SECUREDISPLAY: securedisplay ta ucode is not available
Mär 24 12:25:01 ymir kernel: amdgpu 0000:06:00.0: amdgpu: SMU is resuming...
Mär 24 12:25:01 ymir kernel: amdgpu 0000:06:00.0: amdgpu: dpm has been disabled
Mär 24 12:25:01 ymir kernel: amdgpu 0000:06:00.0: amdgpu: SMU is resumed successfully!
Mär 24 12:25:01 ymir kernel: [drm] DMUB hardware initialized: version=0x01010028
Mär 24 12:25:01 ymir kernel: [drm] kiq ring mec 2 pipe 1 q 0
Mär 24 12:25:01 ymir kernel: [drm] VCN decode and encode initialized successfully(under DPG Mode).
Mär 24 12:25:01 ymir kernel: [drm] JPEG decode initialized successfully.
Mär 24 12:25:01 ymir kernel: amdgpu 0000:06:00.0: amdgpu: ring gfx uses VM inv eng 0 on hub 0
Mär 24 12:25:01 ymir kernel: amdgpu 0000:06:00.0: amdgpu: ring gfx_low uses VM inv eng 1 on hub 0
Mär 24 12:25:01 ymir kernel: amdgpu 0000:06:00.0: amdgpu: ring gfx_high uses VM inv eng 4 on hub 0
Mär 24 12:25:01 ymir kernel: amdgpu 0000:06:00.0: amdgpu: ring comp_1.0.0 uses VM inv eng 5 on hub 0
Mär 24 12:25:01 ymir kernel: amdgpu 0000:06:00.0: amdgpu: ring comp_1.1.0 uses VM inv eng 6 on hub 0
Mär 24 12:25:01 ymir kernel: amdgpu 0000:06:00.0: amdgpu: ring comp_1.2.0 uses VM inv eng 7 on hub 0
Mär 24 12:25:01 ymir kernel: amdgpu 0000:06:00.0: amdgpu: ring comp_1.3.0 uses VM inv eng 8 on hub 0
Mär 24 12:25:01 ymir kernel: amdgpu 0000:06:00.0: amdgpu: ring comp_1.0.1 uses VM inv eng 9 on hub 0
Mär 24 12:25:01 ymir kernel: amdgpu 0000:06:00.0: amdgpu: ring comp_1.1.1 uses VM inv eng 10 on hub 0
Mär 24 12:25:01 ymir kernel: amdgpu 0000:06:00.0: amdgpu: ring comp_1.2.1 uses VM inv eng 11 on hub 0
Mär 24 12:25:01 ymir kernel: amdgpu 0000:06:00.0: amdgpu: ring comp_1.3.1 uses VM inv eng 12 on hub 0
Mär 24 12:25:01 ymir kernel: amdgpu 0000:06:00.0: amdgpu: ring kiq_0.2.1.0 uses VM inv eng 13 on hub 0
Mär 24 12:25:01 ymir kernel: amdgpu 0000:06:00.0: amdgpu: ring sdma0 uses VM inv eng 0 on hub 8
Mär 24 12:25:01 ymir kernel: amdgpu 0000:06:00.0: amdgpu: ring vcn_dec uses VM inv eng 1 on hub 8
Mär 24 12:25:01 ymir kernel: amdgpu 0000:06:00.0: amdgpu: ring vcn_enc0 uses VM inv eng 4 on hub 8
Mär 24 12:25:01 ymir kernel: amdgpu 0000:06:00.0: amdgpu: ring vcn_enc1 uses VM inv eng 5 on hub 8
Mär 24 12:25:01 ymir kernel: amdgpu 0000:06:00.0: amdgpu: ring jpeg_dec uses VM inv eng 6 on hub 8
Mär 24 12:25:01 ymir kernel: PM: hibernation: Basic memory bitmaps freed
Mär 24 12:25:01 ymir kernel: OOM killer enabled.
Mär 24 12:25:01 ymir kernel: Restarting tasks ...
Mär 24 12:25:01 ymir kernel: usb 6-3: USB disconnect, device number 6
Mär 24 12:25:01 ymir kernel: pci_bus 0000:01: Allocating resources
Mär 24 12:25:01 ymir kernel: pci_bus 0000:02: Allocating resources
Mär 24 12:25:01 ymir kernel: pci_bus 0000:03: Allocating resources
Mär 24 12:25:01 ymir kernel: pci_bus 0000:04: Allocating resources
Mär 24 12:25:01 ymir kernel: pci_bus 0000:05: Allocating resources
Mär 24 12:25:01 ymir kernel: done.
Mär 24 12:25:01 ymir kernel: PM: hibernation: hibernation exit
Mär 24 12:25:01 ymir kernel: pci_bus 0000:06: Allocating resources
Mär 24 12:25:01 ymir wpa_supplicant[1238]: wlan0: CTRL-EVENT-DSCP-POLICY clear_all
Mär 24 12:25:01 ymir systemd-sleep[36504]: System returned from sleep operation 'hibernate'.
Mär 24 12:25:01 ymir systemd[1]: systemd-hibernate.service: Deactivated successfully.
Mär 24 12:25:01 ymir systemd[1]: Finished System Hibernate.
Mär 24 12:25:01 ymir systemd[1]: systemd-hibernate.service: Consumed 3.847s CPU time.
Mär 24 12:25:01 ymir systemd[1]: Reached target System Hibernation.
Mär 24 12:25:01 ymir systemd[1]: Stopped target Sleep.
Mär 24 12:25:01 ymir systemd-logind[1120]: Operation 'hibernate' finished.
Mär 24 12:25:01 ymir systemd[1]: Stopped target System Hibernation.
Mär 24 12:25:01 ymir NetworkManager[1130]: <info>  [1711279501.9477] manager: sleep: wake requested (sleeping: yes  enabled: yes)
Mär 24 12:25:01 ymir NetworkManager[1130]: <info>  [1711279501.9479] device (enp2s0f0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Mär 24 12:25:01 ymir kdeconnectd[1758]: 2024-03-24T12:25:01 default: Error sending UDP packet: QAbstractSocket::NetworkError
Mär 24 12:25:01 ymir kernel: Generic FE-GE Realtek PHY r8169-0-200:00: attached PHY driver (mii_bus:phy_addr=r8169-0-200:00, irq=MAC)
Mär 24 12:25:02 ymir systemd[1]: Starting Fingerprint Authentication Daemon...
Mär 24 12:25:02 ymir kernel: usb 6-3: new full-speed USB device number 7 using xhci_hcd
Mär 24 12:25:02 ymir kdeconnectd[1758]: 2024-03-24T12:25:02 kdeconnect.core: Failed to open any MDNS client sockets
Mär 24 12:25:02 ymir wpa_supplicant[1238]: wlan0: CTRL-EVENT-DSCP-POLICY clear_all
Mär 24 12:25:02 ymir wpa_supplicant[1238]: nl80211: deinit ifname=wlan0 disabled_11b_rates=0
Mär 24 12:25:02 ymir kdeconnectd[1758]: 2024-03-24T12:25:02 kdeconnect.core: Failed to open any MDNS server sockets
Mär 24 12:25:02 ymir NetworkManager[1130]: <info>  [1711279502.0996] device (wlan0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Mär 24 12:25:02 ymir kernel: r8169 0000:02:00.0 enp2s0f0: Link is Down
Mär 24 12:25:02 ymir NetworkManager[1130]: <info>  [1711279502.1018] device (p2p-dev-wlan0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Mär 24 12:25:02 ymir NetworkManager[1130]: <info>  [1711279502.1020] manager: NetworkManager state is now DISCONNECTED
Mär 24 12:25:02 ymir systemd[1]: Started Fingerprint Authentication Daemon.
Mär 24 12:25:02 ymir NetworkManager[1130]: <info>  [1711279502.1674] device (wlan0): supplicant interface state: internal-starting -> disconnected
Mär 24 12:25:02 ymir NetworkManager[1130]: <info>  [1711279502.1674] device (p2p-dev-wlan0): state change: unavailable -> unmanaged (reason 'removed', sys-iface-state: 'removed')
Mär 24 12:25:02 ymir NetworkManager[1130]: <info>  [1711279502.1678] Wi-Fi P2P device controlled by interface wlan0 created
Mär 24 12:25:02 ymir NetworkManager[1130]: <info>  [1711279502.1681] manager: (p2p-dev-wlan0): new 802.11 Wi-Fi P2P device (/org/freedesktop/NetworkManager/Devices/9)
Mär 24 12:25:02 ymir NetworkManager[1130]: <info>  [1711279502.1683] device (p2p-dev-wlan0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Mär 24 12:25:02 ymir NetworkManager[1130]: <info>  [1711279502.1691] device (wlan0): state change: unavailable -> disconnected (reason 'supplicant-available', sys-iface-state: 'managed')
Mär 24 12:25:02 ymir NetworkManager[1130]: <info>  [1711279502.1699] device (p2p-dev-wlan0): state change: unavailable -> disconnected (reason 'none', sys-iface-state: 'managed')
Mär 24 12:25:02 ymir kernel: usb 6-3: New USB device found, idVendor=06cb, idProduct=00bd, bcdDevice= 0.00
Mär 24 12:25:02 ymir kernel: usb 6-3: New USB device strings: Mfr=0, Product=0, SerialNumber=1
Mär 24 12:25:02 ymir kernel: usb 6-3: SerialNumber: a16c43e87336
Mär 24 12:25:02 ymir mtp-probe[36601]: checking bus 6, device 7: "/sys/devices/pci0000:00/0000:00:08.1/0000:06:00.4/usb6/6-3"
Mär 24 12:25:02 ymir mtp-probe[36601]: bus: 6, device: 7 was not an MTP device
Mär 24 12:25:02 ymir mtp-probe[36603]: checking bus 6, device 7: "/sys/devices/pci0000:00/0000:00:08.1/0000:06:00.4/usb6/6-3"
Mär 24 12:25:02 ymir mtp-probe[36603]: bus: 6, device: 7 was not an MTP device
Mär 24 12:25:05 ymir systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
Mär 24 12:25:05 ymir kscreenlocker_greet[36413]: qt.qpa.wayland: Could not create EGL surface (EGL error 0x3000)
Mär 24 12:25:05 ymir kscreenlocker_greet[36413]: Failed to write to the pipe: Ungültiger Dateideskriptor.
Mär 24 12:25:05 ymir wpa_supplicant[1238]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=DRIVER type=COUNTRY alpha2=DE
Mär 24 12:25:05 ymir NetworkManager[1130]: <info>  [1711279505.8438] policy: auto-activating connection 'FRITZ!Box 7430 PJ' (733371cd-1d3e-4290-900d-8de45052f6f2)
Mär 24 12:25:05 ymir NetworkManager[1130]: <info>  [1711279505.8441] device (wlan0): Activation: starting connection 'FRITZ!Box 7430 PJ' (733371cd-1d3e-4290-900d-8de45052f6f2)
Mär 24 12:25:05 ymir NetworkManager[1130]: <info>  [1711279505.8442] device (wlan0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
Mär 24 12:25:05 ymir NetworkManager[1130]: <info>  [1711279505.8444] manager: NetworkManager state is now CONNECTING
Mär 24 12:25:05 ymir NetworkManager[1130]: <info>  [1711279505.8445] device (wlan0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Mär 24 12:25:05 ymir NetworkManager[1130]: <info>  [1711279505.8447] device (wlan0): Activation: (wifi) access point 'FRITZ!Box 7430 PJ' has security, but secrets are required.
Mär 24 12:25:05 ymir NetworkManager[1130]: <info>  [1711279505.8447] device (wlan0): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed')
Mär 24 12:25:05 ymir NetworkManager[1130]: <info>  [1711279505.8448] sup-iface[dcf09bf117661872,5,wlan0]: wps: type pbc start...
Mär 24 12:25:05 ymir NetworkManager[1130]: <info>  [1711279505.8462] device (wlan0): state change: need-auth -> prepare (reason 'none', sys-iface-state: 'managed')
Mär 24 12:25:05 ymir wpa_supplicant[1238]: wlan0: WPS-PBC-ACTIVE
Mär 24 12:25:05 ymir NetworkManager[1130]: <info>  [1711279505.8468] device (wlan0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Mär 24 12:25:05 ymir NetworkManager[1130]: <info>  [1711279505.8472] device (wlan0): Activation: (wifi) connection 'FRITZ!Box 7430 PJ' has security, and secrets exist.  No new secrets needed.
Mär 24 12:25:05 ymir NetworkManager[1130]: <info>  [1711279505.8473] Config: added 'ssid' value 'FRITZ!Box 7430 PJ'
Mär 24 12:25:05 ymir NetworkManager[1130]: <info>  [1711279505.8473] Config: added 'scan_ssid' value '1'
Mär 24 12:25:05 ymir NetworkManager[1130]: <info>  [1711279505.8473] Config: added 'bgscan' value 'simple:30:-70:86400'
Mär 24 12:25:05 ymir NetworkManager[1130]: <info>  [1711279505.8473] Config: added 'key_mgmt' value 'WPA-PSK WPA-PSK-SHA256 FT-PSK SAE FT-SAE'
Mär 24 12:25:05 ymir NetworkManager[1130]: <info>  [1711279505.8474] Config: added 'psk' value '<hidden>'
Mär 24 12:25:05 ymir wpa_supplicant[1238]: wlan0: WPS-CANCEL
Mär 24 12:25:05 ymir NetworkManager[1130]: <info>  [1711279505.8504] device (wlan0): supplicant interface state: disconnected -> scanning
Mär 24 12:25:05 ymir NetworkManager[1130]: <info>  [1711279505.8505] device (p2p-dev-wlan0): supplicant management interface state: disconnected -> scanning
Mär 24 12:25:05 ymir kded6[1487]: kf.networkmanagerqt: void NetworkManager::ConnectionPrivate::onPropertiesChanged(const QVariantMap&) Unhandled property "VersionId"
Mär 24 12:25:05 ymir plasmashell[1524]: kf.networkmanagerqt: void NetworkManager::ConnectionPrivate::onPropertiesChanged(const QVariantMap&) Unhandled property "VersionId"
Mär 24 12:25:05 ymir wpa_supplicant[1238]: wlan0: SME: Trying to authenticate with e0:28:6d:25:60:42 (SSID='FRITZ!Box 7430 PJ' freq=2437 MHz)
Mär 24 12:25:05 ymir kernel: wlan0: 80 MHz not supported, disabling VHT
Mär 24 12:25:05 ymir NetworkManager[1130]: <info>  [1711279505.9242] device (wlan0): supplicant interface state: scanning -> authenticating
Mär 24 12:25:05 ymir NetworkManager[1130]: <info>  [1711279505.9243] device (p2p-dev-wlan0): supplicant management interface state: scanning -> authenticating
Mär 24 12:25:05 ymir kernel: wlan0: authenticate with e0:28:6d:25:60:42 (local address=44:af:28:3b:7b:c1)
Mär 24 12:25:05 ymir kernel: wlan0: send auth to e0:28:6d:25:60:42 (try 1/3)
Mär 24 12:25:05 ymir wpa_supplicant[1238]: wlan0: Trying to associate with e0:28:6d:25:60:42 (SSID='FRITZ!Box 7430 PJ' freq=2437 MHz)
Mär 24 12:25:05 ymir NetworkManager[1130]: <info>  [1711279505.9600] device (wlan0): supplicant interface state: authenticating -> associating
Mär 24 12:25:05 ymir NetworkManager[1130]: <info>  [1711279505.9601] device (p2p-dev-wlan0): supplicant management interface state: authenticating -> associating
Mär 24 12:25:05 ymir kernel: wlan0: authenticated
Mär 24 12:25:05 ymir kernel: wlan0: associate with e0:28:6d:25:60:42 (try 1/3)
Mär 24 12:25:05 ymir kernel: wlan0: RX AssocResp from e0:28:6d:25:60:42 (capab=0x1431 status=0 aid=6)
Mär 24 12:25:06 ymir wpa_supplicant[1238]: wlan0: Associated with e0:28:6d:25:60:42
Mär 24 12:25:06 ymir wpa_supplicant[1238]: wlan0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
Mär 24 12:25:06 ymir kernel: wlan0: associated
Mär 24 12:25:06 ymir kernel: wlan0: Limiting TX power to 20 (20 - 0) dBm as advertised by e0:28:6d:25:60:42
Mär 24 12:25:06 ymir NetworkManager[1130]: <info>  [1711279506.0217] device (wlan0): supplicant interface state: associating -> 4way_handshake
Mär 24 12:25:06 ymir NetworkManager[1130]: <info>  [1711279506.0218] device (p2p-dev-wlan0): supplicant management interface state: associating -> 4way_handshake
Mär 24 12:25:06 ymir wpa_supplicant[1238]: wlan0: WPA: Key negotiation completed with e0:28:6d:25:60:42 [PTK=CCMP GTK=CCMP]
Mär 24 12:25:06 ymir wpa_supplicant[1238]: wlan0: CTRL-EVENT-CONNECTED - Connection to e0:28:6d:25:60:42 completed [id=0 id_str=]
Mär 24 12:25:06 ymir NetworkManager[1130]: <info>  [1711279506.1233] device (wlan0): supplicant interface state: 4way_handshake -> completed
Mär 24 12:25:06 ymir NetworkManager[1130]: <info>  [1711279506.1234] device (wlan0): Activation: (wifi) Stage 2 of 5 (Device Configure) successful. Connected to wireless network "FRITZ!Box 7430 PJ"
Mär 24 12:25:06 ymir NetworkManager[1130]: <info>  [1711279506.1234] device (p2p-dev-wlan0): supplicant management interface state: 4way_handshake -> completed
Mär 24 12:25:06 ymir wpa_supplicant[1238]: wlan0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-41 noise=9999 txrate=52000
Mär 24 12:25:06 ymir NetworkManager[1130]: <info>  [1711279506.1493] device (wlan0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
Mär 24 12:25:06 ymir NetworkManager[1130]: <info>  [1711279506.1502] dhcp4 (wlan0): activation: beginning transaction (timeout in 45 seconds)
Mär 24 12:25:06 ymir avahi-daemon[1107]: Joining mDNS multicast group on interface wlan0.IPv6 with address fe80::7fab:69bd:643f:785.
Mär 24 12:25:06 ymir avahi-daemon[1107]: New relevant interface wlan0.IPv6 for mDNS.
Mär 24 12:25:06 ymir avahi-daemon[1107]: Registering new address record for fe80::7fab:69bd:643f:785 on wlan0.*.
Mär 24 12:25:06 ymir NetworkManager[1130]: <info>  [1711279506.1661] dhcp4 (wlan0): state changed new lease, address=192.168.178.41, acd pending
Mär 24 12:25:06 ymir NetworkManager[1130]: <info>  [1711279506.3553] dhcp4 (wlan0): state changed new lease, address=192.168.178.41
Mär 24 12:25:06 ymir NetworkManager[1130]: <info>  [1711279506.3559] policy: set 'FRITZ!Box 7430 PJ' (wlan0) as default for IPv4 routing and DNS
Mär 24 12:25:06 ymir avahi-daemon[1107]: Joining mDNS multicast group on interface wlan0.IPv4 with address 192.168.178.41.
Mär 24 12:25:06 ymir avahi-daemon[1107]: New relevant interface wlan0.IPv4 for mDNS.
Mär 24 12:25:06 ymir avahi-daemon[1107]: Registering new address record for 192.168.178.41 on wlan0.IPv4.
Mär 24 12:25:06 ymir NetworkManager[1130]: <info>  [1711279506.3725] device (wlan0): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
Mär 24 12:25:06 ymir systemd[1]: Starting Network Manager Script Dispatcher Service...
Mär 24 12:25:06 ymir systemd[1]: Started Network Manager Script Dispatcher Service.
Mär 24 12:25:06 ymir NetworkManager[1130]: <info>  [1711279506.4333] device (wlan0): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
Mär 24 12:25:06 ymir NetworkManager[1130]: <info>  [1711279506.4337] device (wlan0): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
Mär 24 12:25:06 ymir NetworkManager[1130]: <info>  [1711279506.4343] manager: NetworkManager state is now CONNECTED_SITE
Mär 24 12:25:06 ymir NetworkManager[1130]: <info>  [1711279506.4373] device (wlan0): Activation: successful, device activated.
Mär 24 12:25:06 ymir NetworkManager[1130]: <info>  [1711279506.5919] manager: NetworkManager state is now CONNECTED_GLOBAL
Mär 24 12:25:06 ymir kdeconnectd[1758]: 2024-03-24T12:25:06 kdeconnect.core: Failed to send mDNS query: Die angeforderte Adresse kann nicht zugewiesen werden
Mär 24 12:25:07 ymir NetworkManager[1130]: <info>  [1711279507.8726] dhcp6 (wlan0): activation: beginning transaction (timeout in 45 seconds)
Mär 24 12:25:07 ymir NetworkManager[1130]: <info>  [1711279507.8734] policy: set 'FRITZ!Box 7430 PJ' (wlan0) as default for IPv6 routing and DNS
Mär 24 12:25:07 ymir avahi-daemon[1107]: Leaving mDNS multicast group on interface wlan0.IPv6 with address fe80::7fab:69bd:643f:785.
Mär 24 12:25:07 ymir avahi-daemon[1107]: Joining mDNS multicast group on interface wlan0.IPv6 with address 2a01:c23:71a0:a200:aed0:84fa:a53c:7a0f.
Mär 24 12:25:07 ymir NetworkManager[1130]: <info>  [1711279507.8780] dhcp6 (wlan0): state changed new lease
Mär 24 12:25:07 ymir avahi-daemon[1107]: Registering new address record for 2a01:c23:71a0:a200:aed0:84fa:a53c:7a0f on wlan0.*.
Mär 24 12:25:07 ymir avahi-daemon[1107]: Withdrawing address record for fe80::7fab:69bd:643f:785 on wlan0.
Mär 24 12:25:16 ymir systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
maybe it has something todo with my Ryzen 7 4750u ?
I read about problems in the past with several kernel versions…
It looks like this task cannot succeed: Disabling non-boot CPUs
I suggest you investigate your UEFI/BIOS settings for something relevant.
thank you, that was it. didn’t know there was an option like that in the UEFI. Sleepmode was optimized for windows, i changed it to linux and now it goes to sleep mode. :+1: :+1: :+1:
But strangely it did not saved anything of my open applications. All windows were closed. Just like a normal reboot.
But maybe i will open another thread for that problem…
It’s better.
It sounds like hibernation is not configured correctly, or something else.
Journal logs should provide useful info.
If you have configured it manually (the Arch way), review relevant files and compare to Archwiki instructions.
Dracut module was missing:
https://wiki.archlinux.org/title/Dracut#Hibernation
now its all working :sunglasses: :+1:
