Title.
In detail, when I try to install Anbox (my cousin wants an Android emulator) I would install the anbox-support
package from the AUR, sudo modprobe -a ashmem_linux binder_linux
and after the binderfs creation and adding it to /etc/fstab/
with the nofail
option and then Anbox would work! yay! sort of. It would be glitchy
(that’s always got to happen with smth I put ages into installing, snaps suck, so I avoid them)
and then I’d reboot, and then it just shows GRUB, but then it just won’t go past this:
Loading kernel linux...
loading initial ramdisk...
and it just stops dead.
I am now reinstalling (btrfs snapshots nor fallback initramfs helped) and wrote this from the live env. By the time I wake up it should be done.
inxi -Fxza
[liveuser@eos-2022.06.23 ~]$ inxi -Fxza
Kernel: 5.18.5-arch1-1 arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
parameters: initrd=\arch\boot\intel-ucode.img
initrd=\arch\boot\amd-ucode.img
initrd=\arch\boot\x86_64\initramfs-linux.img archisobasedir=arch
archisolabel=EOS_202206 cow_spacesize=10G
module_blacklist=nvidia,nvidia_modeset,nvidia_uvm,nvidia_drm
nouveau.modeset=1 i915.modeset=1 radeon.modeset=1 nvme_load=yes
Desktop: Xfce v: 4.16.0 tk: Gtk v: 3.24.29 info: xfce4-panel wm: xfwm
v: 4.16.1 vt: 1 dm: LightDM v: 1.30.0 Distro: EndeavourOS base: Arch Linux
Type: Laptop System: Hewlett-Packard product: HP ProBook 4540s
v: A1018C1100 serial: <superuser required> Chassis: type: 10
Mobo: Hewlett-Packard model: 17F6 v: KBC Version 58.21
serial: <superuser required> UEFI: Hewlett-Packard v: 68IRR Ver. F.67
date: 05/30/2018
Battery:
ID-1: BAT0 charge: 0.0 Wh (0.0%) condition: 47.5/47.5 Wh (100.0%)
volts: 10.8 min: 10.8 model: Hewlett-Packard Primary type: Li-ion
serial: <filter> status: N/A
Info: model: Intel Core i5-3230M bits: 64 type: MT MCP arch: Ivy Bridge
gen: core 3 built: 2012-15 process: Intel 22nm family: 6
model-id: 0x3A (58) stepping: 9 microcode: 0x21
Topology: cpus: 1x cores: 2 tpc: 2 threads: 4 smt: enabled cache:
L1: 128 KiB desc: d-2x32 KiB; i-2x32 KiB L2: 512 KiB desc: 2x256 KiB
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 1665 high: 1856 min/max: 1200/3200 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 1554 2: 1856 3: 1812
4: 1439 bogomips: 20759
Flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
Vulnerabilities:
Type: itlb_multihit status: KVM: VMX disabled
Type: l1tf
mitigation: PTE Inversion; VMX: conditional cache flushes, SMT vulnerable
Type: spec_store_bypass
mitigation: Speculative Store Bypass disabled via prctl
Type: spectre_v1
STIBP: conditional, RSB filling
Type: srbds status: Vulnerable: No microcode
Device-1: Intel 3rd Gen Core processor Graphics vendor: Hewlett-Packard
driver: i915 v: kernel arch: Gen7 process: Intel 22nm built: 2012-13 ports:
active: LVDS-1 empty: DP-1,HDMI-A-1,VGA-1 bus-ID: 00:02.0
chip-ID: 8086:0166 class-ID: 0300
Device-2: Chicony HP HD Webcam [Fixed] type: USB driver: uvcvideo
bus-ID: 1-1.3:4 chip-ID: 04f2:b372 class-ID: 0e02
Display: server: X.Org v: 21.1.3 compositor: xfwm v: 4.16.1 driver: X:
loaded: intel unloaded: modesetting alternate: fbdev,vesa gpu: i915
display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.21x7.99")
s-diag: 414mm (16.31")
Monitor-1: LVDS-1 mapped: LVDS1 model: Chi Mei Opto 0x15a1 built: 2011
res: 1366x768 hz: 60 dpi: 102 gamma: 1.2 size: 340x190mm (13.39x7.48")
diag: 394mm (15.5") ratio: 16:9 modes: 1366x768
OpenGL: renderer: Mesa Intel HD Graphics 4000 (IVB GT2)
v: 4.2 Mesa 22.1.2 direct render: Yes
Device-1: Intel 7 Series/C216 Family High Definition Audio
vendor: Hewlett-Packard driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:1e20 class-ID: 0403
Sound Server-1: ALSA v: k5.18.5-arch1-1 running: yes
Sound Server-2: PulseAudio v: 16.1 running: no
Sound Server-3: PipeWire v: 0.3.52 running: yes
Device-1: Ralink RT3290 Wireless 802.11n 1T/1R PCIe vendor: Hewlett-Packard
driver: rt2800pci v: 2.3.0 modules: wl pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 bus-ID: 03:00.0 chip-ID: 1814:3290 class-ID: 0280
vendor: Hewlett-Packard driver: r8169 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 2000 bus-ID: 04:00.0 chip-ID: 10ec:8168
class-ID: 0200
IF: enp4s0 state: down mac: <filter>
Bluetooth:
Device-1: Ralink RT3290 Bluetooth vendor: Hewlett-Packard driver: N/A pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.1 chip-ID: 1814:3298
class-ID: 0d11
Report: bt-service: enabled,stopped note: tool can't run
Local Storage: total: 494.67 GiB used: 2 GiB (0.4%)
ID-1: /dev/sda maj-min: 8:0 vendor: HGST (Hitachi) model: HTS725050A7E630
size: 465.76 GiB block-size: physical: 4096 B logical: 512 B
speed: 3.0 Gb/s type: HDD rpm: 7200 serial: <filter> rev: A440
scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 type: USB vendor: PNY model: USB 2.0 FD
size: 28.91 GiB block-size: physical: 512 B logical: 512 B type: N/A
serial: <filter> rev: PMAP scheme: MBR
SMART Message: Unknown USB bridge. Flash drive/Unsupported enclosure?
ID-1: / raw-size: N/A size: 10 GiB used: 704.3 MiB (6.9%) fs: overlay
source: ERR-102
System Temperatures: cpu: 48.0 C mobo: 0.0 C
Fan Speeds (RPM): N/A
Processes: 221 Uptime: 50m wakeups: 2 Memory: 3.72 GiB
used: 2.61 GiB (70.2%) Init: systemd v: 251 default: multi-user
tool: systemctl Compilers: gcc: 12.1.0 Packages: pacman: 898 lib: 212
Shell: Bash v: 5.1.16 running-in: xfce4-terminal inxi: 3.3.18
