Installer wishlist
Okay i have installed Deepin on bare metal. Now i need things fixed. :stuck_out_tongue:
Edit: How do i stop it from trying to auto mount my other drives when opening an app in the dock?
There should be an option in the file manager preferences as far as I know
Do you also get the problem closing the left over icons from welcome screen and eos-log-tool and reflector simple? They have multiple instances of the Endeavour icon and won’t close.
Screen Capture_select-area_20200711153414
Yep, everyone does :expressionless: Welcome to Arch Deepin :slight_smile:
Go here:
Screen Capture_20200711153701
Uncheck automount. At least on my system.
deepin likes to be rebooted :rofl: btw
At least it’s not freezing anymore with Window effects on and Htop is working. I can live with the minimize maximize issue but i would like the mutitasking to work. The left over icons i could stop from misbehaving by removing those apps but @manuel would be so hurt. I can’t bring myself to do that. :grimacing: :wink:
It’s not just welcome app icons so no need to remove welcome. It is still bugged atm.
Right, many apps are stuck like that. It is surely not the applications problem.
@ricklinux, just remove the Deepin panel :slight_smile:
I just auto-hide it and ignore it until I need something really specific. Other wise i just use plank-git and for more functionality you can just add the applications applet to the plank. It is also the only way to get some icons to dock on plank with deepin but totally doable :grin:
What do i use instead of deepin panel?
Sorry totally off topic but does anyone else see the irony in the fact that @ricklinux is from Canada and his avatar is an USA space shuttle and I am from USA and my avatar is a penguin? :rofl:
I do the same recently, don’t want to see it too often :sweat_smile:
No idea, maybe one from another DE? :thinking:
We don’t have any spaceships!
I balme it on poutine! :grin:
Actually I’ve never tried Poutine yet my families fast food restaurants have it since 1973!
Well - the space shuttle relies on the Canadarm to get work done! (?)
Not sure about the Penguin, though…:laughing:
The best Poutine ever is at Montreal ! :fries:
You haven’t tried ours. :yum:
Back on topic (apologies), but an inxi script to check hardware detection would be useful for newbies.
It is already in the EndeavourOS repository :yum:
Here is mine:
[elloquin@elloquin-elloquin ~]$ inxi -Fxxxza --no-host
System:    Kernel: 5.7.7-arch1-1 x86_64 bits: 64 compiler: gcc v: 10.1.0
           parameters: BOOT_IMAGE=/boot/vmlinuz-linux root=UUID=c38c65da-8e2c-43e1-8e5e-535b7f1a678d
           rw quiet resume=UUID=5eccc442-7c63-4f3c-87c2-9f597cb18b7e loglevel=3 nowatchdog
           Desktop: Deepin 20 tk: Qt 5.15.0 info: dde-dock, plank wm: kwin_x11 dm: LightDM 1.30.0
           Distro: EndeavourOS
Machine:   Type: Desktop Mobo: ASUSTeK model: CROSSHAIR VI HERO v: Rev 1.xx serial: <filter>
           UEFI: American Megatrends v: 6401 date: 12/07/2018
CPU:       Topology: 8-Core model: AMD Ryzen 7 1800X bits: 64 type: MT MCP arch: Zen family: 17 (23)
           model-id: 1 stepping: 1 microcode: 8001137 L2 cache: 4096 KiB
           flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 127802
           Speed: 3396 MHz min/max: 2200/4000 MHz boost: disabled Core speeds (MHz): 1: 3954 2: 3983
           3: 2193 4: 2197 5: 2198 6: 2195 7: 2196 8: 2191 9: 2004 10: 2002 11: 2005 12: 2027 13: 1997
           14: 2003 15: 2197 16: 2194
           Vulnerabilities: Type: itlb_multihit status: Not affected
           Type: spec_store_bypass mitigation: Speculative Store Bypass disabled via prctl and seccomp
           Type: spectre_v1 mitigation: usercopy/swapgs barriers and __user pointer sanitization
           Type: spectre_v2
           mitigation: Full AMD retpoline, IBPB: conditional, STIBP: disabled, RSB filling
Graphics:  Device-1: AMD Vega 10 XL/XT [Radeon RX Vega 56/64] vendor: ASUSTeK driver: amdgpu v: kernel
           bus ID: 0d:00.0 chip ID: 1002:687f
           Display: x11 server: X.Org 1.20.8 compositor: kwin_x11 driver: amdgpu,ati
           unloaded: fbdev,modesetting,vesa display ID: :0 screens: 1
           Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 506x284mm (19.9x11.2") s-diag: 580mm (22.8")
           Monitor-1: HDMI-A-0 res: 1920x1080 hz: 60 dpi: 82 size: 598x336mm (23.5x13.2")
           diag: 686mm (27")
Audio:     Device-1: AMD Vega 10 HDMI Audio [Radeon Vega 56/64] driver: snd_hda_intel v: kernel
           bus ID: 0d:00.1 chip ID: 1002:aaf8
           Device-2: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
           bus ID: 0f:00.3 chip ID: 1022:1457
           Sound Server: ALSA v: k5.7.7-arch1-1
Network:   Device-1: Intel I211 Gigabit Network vendor: ASUSTeK driver: igb v: 5.6.0-k port: e000
           bus ID: 05:00.0 chip ID: 8086:1539
           IF: enp5s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Drives:    Local Storage: total: 12.96 TiB used: 212.40 GiB (1.6%)
           ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 970 EVO 250GB size: 232.89 GiB block size:
           physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 serial: <filter> rev: 1B2QEXE7
           scheme: GPT
           ID-2: /dev/sda vendor: Samsung model: SSD 860 EVO 1TB size: 931.51 GiB block size:
           physical: 512 B logical: 512 B speed: 6.0 Gb/s serial: <filter> rev: 1B6Q scheme: GPT
           ID-3: /dev/sdb vendor: Samsung model: SSD 860 EVO 1TB size: 931.51 GiB block size:
           physical: 512 B logical: 512 B speed: 6.0 Gb/s serial: <filter> rev: 3B6Q
           ID-4: /dev/sdc vendor: Samsung model: SSD 860 EVO 1TB size: 931.51 GiB block size:
           ID-5: /dev/sdd vendor: Samsung model: SSD 860 EVO 1TB size: 931.51 GiB block size:
           ID-6: /dev/sde type: USB vendor: Western Digital model: WD easystore 25FB size: 9.10 TiB
           block size: physical: 4096 B logical: 512 B serial: <filter> rev: 3004 scheme: GPT
Partition: ID-1: / raw size: 215.82 GiB size: 211.43 GiB (97.97%) used: 8.59 GiB (4.1%) fs: ext4
           dev: /dev/nvme0n1p2
           ID-2: /home raw size: 931.51 GiB size: 1.82 TiB (200.00%) used: 203.81 GiB (10.9%)
           fs: btrfs dev: /dev/sda1
Swap:      Kernel: swappiness: 60 (default) cache pressure: 100 (default)
           ID-1: swap-1 type: partition size: 16.09 GiB used: 0 KiB (0.0%) priority: -2
           dev: /dev/nvme0n1p3
Sensors:   System Temperatures: cpu: 39.2 C mobo: N/A gpu: amdgpu temp: 26 C
           Fan Speeds (RPM): N/A gpu: amdgpu fan: 0
Info:      Processes: 378 Uptime: 58m Memory: 31.35 GiB used: 1.62 GiB (5.2%) Init: systemd v: 245
           Compilers: gcc: 10.1.0 Packages: pacman: 975 lib: 258 Shell: Bash v: 5.0.17
           running in: deepin-terminal inxi: 3.1.04
