I installed eos without adding the efi partition. It complained, but that’s fine at the time, because efi is controlled by another linux install. I just added eos to my grub.cfg.
Now I want the eos install to be in control. grub-install doesn’t work because I didn’t include it on original install.
I don’t want to re-create efi partition because I have other OS’s installed.
I tried mounting efi to “/mnt”, which it did but “/boot/efi” isn’t there.
Is there a way to create folder “/efi/EFI” and add eos to the mix. efibootmgr magic??
This is most likely simple, but has slipped my mind.
I don’t know how you did it but if you are doing manual partitions you can select the /boot/efi partition that you have for current setup and eos will take over but use that current efi partition. You just have to browse to that /efi partition and mark it as as /boot during the install.
you can use the efi partition already there from another linux or windows install, to do so you need to add this to fstab to make sure it is mounted on the right place like so:
put in the uuid of the efi partition from second installed os
then mount it manually sudo mount /dev/sdXn /boot/efi
you need to get uuid for the partition and current dev path to do so:
Thank you!
I tried all the usual fixes. None worked because eos didn’t have ‘efi’ mount on boot.
I could mount it after boot, but that isn’t the same.
Didn’t think fstab would do the trick. I had to use to additional commands to complete the operation:
What you do was install grub on mbr (MasterBootRecord) [grub-install /dev/nvme0n1p1] what is not the way to do it on gpt efi systems… where you install into filesystem (/boot/efi) same as what you have on debian systems
