Would there be any issue if I install endaevouros without plugging in my laptop to a power source as the battery has already much power in it right now.
Any help would be appreciated.
As long as the battery doesn’t die in the process, it should work fine.
And what about the net install (online install) while your laptop is unplugged to a power source.
Is online install fine too without your laptop being plugged in to a power source?
Yes. As long as you have a working network connection.
So both methods of installation are fine without the laptop being plugged in to a power source.
Am I right?
and
Or not, if you go for an offline install.
Yes.
Offline install is around 5 or 7 mn depending your machine
Online install is between 10mn to 50mn depending your connexion speed (adsl, fiber) and machine
