thanks for the report!
Only an updated version with latest kernel headers and firmware
Iām hopeful it works on the newer AMD GPU Ryzen 3 2200G and up as they are way newer than what i have in desktop cards on my older machines which are also Bios systems.
Thank you for that. The (Preempt) Installation ISO worked fine. There were some strange lines during the iso loading and then a grey screen. After a delay of two or three seconds I got the welcome screen with no artefacts. I checked out various items and it all seemed stable. Iām not going to re-install just yet because Iāve got a good system running. Iāll wait until you reissue the updated ISO to all users.
My system is Asrock Deskmini A300; Ryzen 3 2200G with Radeon Vega Graphics; 8GB DDR4 2400 RAM.
@davidw Glad this worked better on your Ryzen3 2200G. I could only test it on my Radeons and they are older desktop cards but it was night and day. No artifacts.
@joekamprad I also tested this ISO on my Nvidia GTX1060 on Uefi and it boots up no problem with same grey screen and desktop loads. No artifacts no video display issues.
I also installed it into virtualbox without any apparent issues related to the iso.
hi anyone with AMD graphics here could you testing boot on latest snapshot for us?
@ricklinux @ringo @davidw
only to see if ISO boots fine no need to install.
I have tested it. See my responses above. I canāt see any newer ISO than your preempt one.
yes i have just build one, will be up in 20 minutes:
endeavouros-2019.10.13-x86_64.iso
we want to make sure that it is working for AMD graphics, there was some major updates on Mesa and kernel alsoā¦
OK, Iāll come back later and try it.
@joekamprad
endeavouros-2019.10.13-x86_64.iso booting on Uefi with Nvidia GTX1060
No issue booting ā¦no artifacts.
[liveuser@archiso ~]$ inxi -Fxxxc0
Host: archiso Kernel: 5.3.5-arch1-1-ARCH x86_64 bits: 64 compiler: gcc
v: 9.2.0 Desktop: Xfce 4.14.1 tk: Gtk 3.24.10 info: xfce4-panel wm: xfwm4
dm: LightDM 1.30.0 Distro: EndeavourOS
Type: Desktop Mobo: ASUSTeK model: TUF Z370-PRO GAMING v: Rev 1.xx
serial: <root required> UEFI: American Megatrends v: 2102 date: 07/02/2019
Topology: 6-Core model: Intel Core i7-8086K bits: 64 type: MT MCP
arch: Kaby Lake rev: A L2 cache: 12.0 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
bogomips: 96039
Speed: 800 MHz min/max: 800/5000 MHz Core speeds (MHz): 1: 800 2: 800
3: 800 4: 801 5: 800 6: 800 7: 800 8: 800 9: 800 10: 801 11: 800 12: 800
Device-1: NVIDIA GP104 [GeForce GTX 1060 6GB] vendor: ASUSTeK
driver: nouveau v: kernel bus ID: 01:00.0 chip ID: 10de:1b83
Display: server: X.Org 1.20.5 driver: nouveau compositor: xcompmgr
resolution: 1920x1080~60Hz
Device-1: Intel 200 Series PCH HD Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus ID: 00:1f.3 chip ID: 8086:a2f0
Device-2: NVIDIA GP104 High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus ID: 01:00.1 chip ID: 10de:10f0
Sound Server: ALSA v: k5.3.5-arch1-1-ARCH
Device-1: Intel Ethernet I219-V vendor: ASUSTeK driver: e1000e v: 3.2.6-k
port: f000 bus ID: 00:1f.6 chip ID: 8086:15b8
IF: enp0s31f6 state: down mac: b0:6e:bf:cd:93:e7
Device-2: Qualcomm Atheros AR5418 Wireless Network Adapter [AR5008E
802.11bgn]
vendor: D-Link System DWA-556 Xtreme N driver: ath9k v: kernel port: e000
bus ID: 06:00.0 chip ID: 168c:0024
IF: wlp6s0 state: up mac: 1c:7e:e5:2a:82:e8
Local Storage: total: 4.56 TiB used: 30.9 MiB (0.0%)
ID-1: /dev/nvme0n1 vendor: Corsair model: Force MP500 size: 447.13 GiB
speed: 31.6 Gb/s lanes: 4 serial: 18227996000122430258 rev: E7FM04.C
scheme: GPT
ID-2: /dev/sda vendor: Western Digital model: WDS500G2B0A-00SM50
size: 465.76 GiB speed: 6.0 Gb/s serial: 182220802187 rev: 90WD
scheme: GPT
ID-3: /dev/sdb vendor: Seagate model: ST4000DM004-2CV104 size: 3.64 TiB
speed: 6.0 Gb/s rotation: 5425 rpm serial: WFN03CFC rev: 0001 scheme: GPT
ID-4: /dev/sdc type: USB vendor: Verbatim model: STORE N GO
size: 28.85 GiB serial: 070B6B501FB2D192 rev: PMAP scheme: MBR
ID-1: / size: 10.00 GiB used: 30.9 MiB (0.3%) fs: overlay source: ERR-102
System Temperatures: cpu: 28.0 C mobo: N/A gpu: nouveau temp: 46 C
Fan Speeds (RPM): cpu: 0 gpu: nouveau fan: 0
Processes: 264 Uptime: 4m Memory: 31.30 GiB used: 672.5 MiB (2.1%)
Init: systemd v: 243 target: multi-user.target Compilers: gcc: 9.2.0
Shell: bash v: 5.0.11 running in: xfce4-terminal inxi: 3.0.36
______________________________________________________________________________________
@joekamprad
endeavouros-2019.10.13x86_64.iso booting on Radeon HD 3870
No issues bootingā¦no artifacts
Type: Desktop Mobo: DFI model: 975X serial: <root required> BIOS: Phoenix
v: 6.00 PG date: 10/12/2007
Topology: Quad Core model: Intel Core2 Quad Q6600 bits: 64 type: MCP
arch: Core Merom rev: B L2 cache: 4096 KiB
flags: lm nx pae sse sse2 sse3 ssse3 vmx bogomips: 19162
Speed: 1596 MHz min/max: 1600/2400 MHz Core speeds (MHz): 1: 1596 2: 1597
3: 1597 4: 1599
Device-1: AMD RV670 [Radeon HD 3870] vendor: PC Partner Limited
driver: radeon v: kernel bus ID: 01:00.0 chip ID: 1002:9501
Display: server: X.Org 1.20.5 driver: radeon compositor: xcompmgr
resolution: 1680x1050~60Hz
Device-1: Intel NM10/ICH7 Family High Definition Audio
driver: snd_hda_intel v: kernel bus ID: 00:1b.0 chip ID: 8086:27d8
Device-2: AMD RV670/680 HDMI Audio [Radeon HD 3690/3800 Series]
vendor: PC Partner Limited driver: snd_hda_intel v: kernel bus ID: 01:00.1
chip ID: 1002:aa18
Device-1: Broadcom and subsidiaries BCM4360 802.11ac Wireless Network
Adapter
driver: bcma-pci-bridge v: N/A port: ee00 bus ID: 03:00.0
chip ID: 14e4:43a0
vendor: DFI driver: r8169 v: kernel port: be00 bus ID: 04:00.0
chip ID: 10ec:8168
IF: enp4s0 state: up speed: 1000 Mbps duplex: full mac: 00:01:29:d7:25:ce
Local Storage: total: 494.61 GiB used: 2.7 MiB (0.0%)
ID-1: /dev/sda vendor: Western Digital model: WDS500G2B0A-00SM50
size: 465.76 GiB speed: 3.0 Gb/s serial: 190893801133 rev: 00WD
scheme: GPT
ID-2: /dev/sdb type: USB vendor: Verbatim model: STORE N GO
ID-1: / size: 10.00 GiB used: 2.7 MiB (0.0%) fs: overlay source: ERR-102
System Temperatures: cpu: 28.0 C mobo: N/A gpu: radeon temp: 53 C
Fan Speeds (RPM): N/A
Processes: 175 Uptime: 1m Memory: 7.78 GiB used: 453.0 MiB (5.7%)
I have also tested it on a Radeon HD 7450 no issues.
Computer: Asrock deskmini A300; AMD Ryzen 3 2200G with Radeon Vega Graphics.
Booted from live usb stick: no problem.
Installed in Virtualbox in efi mode: no problem. All of the required facilities seemed to work fine, including automatic resizing and copy from host to guest. It looks like a very good Xfce4 installation. Thanks.
I can confirm as @davidw has posted. I have installed it in Virtualbox with Uefi also with no issues.
quick cleaned my usb and burned the iso with dd , no issuesā¦ for vbox mayby other time
thanks a lot to do testing!!!
this is much of a help for us!!!
install on vbox went fine, but i used a used image and usually forgoth to log, but im sure its a known issue , install on the vbox was xfs install somehow he didnt like had to clean the disk with gparted , usesd erase disk option lol will log next time but nice to see some improvement on it
Continuing the discussion from Installation ISO:
boots perfectly from USB flash drive
AMD ryzen 7
AMD radeon RX 570
thanks for testing!
Awesome! So it should work on the RX 590 and the newer Ryzen 5 3800X then.
