Installation freezes at 12% base system stage
Hello there, trying to install EndeavourOS after hearing good things about it on my home Proxmox server. Have used Arch in the past, am a fluent Debian-based OS user
But unfortunately, the whole system is hard freezing at 12% installing the base system stage
It appears to be fully locked, I cannot touch anything within the desktop
The VM also shows the RAM usage spiked at around 85% and never stops, some kind of crazy memory leak or something.. I’m not sure how to troubleshoot
Just figured I’d report, as I am at a standstill with this distro personally
make sure there is enough RAM - at least 4GB
yes minimum is 4GB of RAM as it will need that to store packagefiles for online installs you can use offline in case you have to install with less RAM.
… and welcome here :enos:
