Installation Failure
Ok, I give up. Have tried 10 attempts to install Endeavour OS, online and offline, to 2 different drives and failed every time .What ever am I doing wrong?
http://termbin.com/n8p5
Have tried with Calamares 3.3.8 but same result.
Cheers
Roger Hart
ERROR: Error while running: OSError: [Errno 30] Read-only file system: '/tmp/calamares-root-zj4b2v_2/efi
This usually means that either your EFI partition needs to be repaired or you came from Windows and didn’t disable fast startup in your windows settings.
We use a customized version of Calamares so that probably wouldn’t work at all.
