Installation failure - SOLVED
Hi,
Having problems installing. Trying to install Plasma.
  • Artemis Nova ISO on Ventoy
  • Updated the mirrors before installing
  • deleted all partitions in gparted, created a new gpt partition.
  • unticked the boxes for hwinfo, ipw2100 and ipw2200-fw
  • tried an offline install
https://termbin.com/3r6m
is this the culprit? 2022-11-04 - 21:54:52 [6]: [PYTHON JOB]: "error: target not found: grub-tools
Exactly. Uncheck it in the package selection section of the installer.
You should find it under EnOS base packages (or similar wording).
Also, I guess that the issue is not present in the latest ISO release.
Are you using and older one?
could be that the iso is a few months old yes
Alright then.
The better option would be to use the latest ISO if you can.
If not, try what I suggested above. Hopefully it all will work out fine.
fixed! version_09 worked out flawlessly. Will remember that for next time. thx!
