Hello,
while installing endeavour os on a previously whiped ssd I encounter the error that pacman Crashes withing calameres.
This leads to calamares trying to unmount the filessystem which hangs indevinetly.
This then results in an rsync error -1 or 12.
Or it leads to the message: Installation Failed. The package manager couldnt make changes to the installed system.
Sorry for the bad formatting. I never encountered this problem. Could anyone help me with this?
I can supply logs and stuff if needed
cactux
April 23, 2025, 2:49pm
2
If you post the install.log someone maybe could.
Provide Installer Logs (calamares ISO LiveSession):
While you are still on the ISO Live Session logs are stored inside livusers home:
/home/liveuser/endeavour-install.log
You can open with text editor or from file browser, or send via tools (needs internet connection):
cat ~/endeavour-install.log | eos-sendlog
You can simply share the short URL it produces inside a terminal.
Hmm, I started the install and still cant see the file in /home/liveuser
Am I missing something?
Did you try installing online or offline ?
I only tried installing online
Which version are you using the latest version or an older version ?
https://termbin.com/15nr
This is a log of a failed offline installation
cactux
April 23, 2025, 3:06pm
8
ZachariasFrings:
When the installation fails, use eos-log-tool
. Check the relevant boxes and post the URL.
I used the latest available ISO on the website
Hmm,
my DE seems to crash after the failed installation. The only thing I can do is reboot my system.
But the above link is a a canceled install that failed. So it should help determining the problem
void Calamares::RequirementsChecker::addCheckedRequirements(Calamares::Module*)
2025-04-23 - 17:02:08 [6]: Got 5 requirement results from "welcome"
2025-04-23 - 17:02:08 [6]: .. Loading "/etc/calamares/branding/endeavouros/show.qml"
2025-04-23 - 17:02:08 [6]: .. No translation for "kb_" "de" using default (en)
2025-04-23 - 17:02:08 [6]: void Calamares::QmlViewStep::loadComplete()
2025-04-23 - 17:02:08 [6]: QML component "qrc:/packagechooserq.qml" QQmlComponent::Ready
2025-04-23 - 17:02:08 [6]: .. QML component complete "qrc:/packagechooserq.qml" creating object
2025-04-23 - 17:02:08 [6]: DEBUG (Qt): getting temp failed for "/dev/nvme0n1" : No such file or directory
2025-04-23 - 17:02:08 [6]: DEBUG (Qt): getting powered on time failed for "/dev/nvme0n1" : No such file or directory
2025-04-23 - 17:02:08 [6]: DEBUG (Qt): getting power cycles failed for "/dev/nvme0n1" : No such file or directory
2025-04-23 - 17:02:09 [6]: DEBUG (Qt): smartctl initialization failed for "/dev/sdb" : No such file or directory
2025-04-23 - 17:02:09 [6]: DEBUG (Qt): error during smart output parsing for "/dev/sdb" : No such file or directory
2025-04-23 - 17:02:09 [2]: WARNING (Qt): unknown file system type "dos" on "/dev/sdb"
Thats the only thing that seems weird. But I ereased my m2 ssd multiple times. I dont see how there could be an instance of DOS on there…
I know tried creating a new partitions on the ssd and a new partition table on the other harddrive.
I am currently running the offline isntaller again
https://termbin.com/w0b6
Is the new log
I found the following reddit-thread:
https://www.reddit.com/r/archcraft/comments/w8zyjh/archcraft_installation_hangup_calamares_unable_to/
Could this be my problem. When using gparted it shows locks on my partitions
cactux
April 23, 2025, 3:45pm
15
Before starting the installer (Calamares), you could use partitionmanager to create a new GPT on your disk. This will erase every partition and data on the disk so do this if you will be installing EOS on the whole disk.
https://termbin.com/rtya
These are the results with a new partition-table
It says something about there being a read-only filesystem. This smells like a permission problem. Can I somehow say calamares to use the superuser?
cactux
April 23, 2025, 4:21pm
17
You could try a manual install.
I would do this:
Reboot the Live ISO.
Create a new GPT.
Make 2 partitions:
2048 MiB FAT32
the rest of the disk, filesystem of your choice: EXT4 or Btrfs (for example)
Start the installer. Choose manual installation.
Mount the FAT32 partition at /efi flag boot
Mount the other partition at /
Go with the default for the rest.
