Greetings! I was eager to check out the Endaveour OS April release, so I downloaded it and did an installation with Cinnamon. However, at the end of the installation, I got an error about systemd-machine-id-setup not existing: https://termbin.com/s0q4
I used this ISO just before on another device, and I verified it, so I’m pretty sure that that’s not the problem… Posting this right before I try again. Maybe I’ll boot in and the system will work anyways.
I figured that out, but the issue seems to be that the iso keeps dropping my connection at totally random times. I got it to the installation part, trying again…
I would just use ethernet but i don’t have access to it at the moment. I’d also like to get the core issue solved so that others can benefit
