Installation failed: "Failed to run pacstrap" - MacBook Pro mid 2011
On my MBP early 2011 (Mbp 8,2), Ubuntu and MX have long been replaced with Fedora 36. Will post from that machine after the current, ongoing update finishes, @manuel
Ok now, here’s my
inxi -Fza
Kernel: 6.0.9-200.fc36.x86_64 arch: x86_64 bits: 64 compiler: gcc
v: 2.37-36.fc36
parameters: BOOT_IMAGE=(hd6,gpt5)/vmlinuz-6.0.9-200.fc36.x86_64
root=UUID=6bfa545c-b27b-44f9-bbd6-a8791d4bffef ro rootflags=subvol=root
rhgb quiet
Desktop: GNOME v: 42.6 tk: GTK v: 3.24.35 wm: gnome-shell dm: 1: GDM
v: 42.0 2: LightDM v: 1.32.0 note: stopped Distro: Fedora release 36
(Thirty Six)
Type: Laptop System: Apple product: MacBookPro8,2 v: 1.0
serial: Chassis: type: 10 v: Mac-94245A3940C91C80
serial:
Mobo: Apple model: Mac-94245A3940C91C80 v: MacBookPro8,2
serial: UEFI: Apple v: 87.0.0.0.0 date: 06/13/2019
Battery:
ID-1: BAT0 charge: 37.2 Wh (81.4%) condition: 45.7/75.2 Wh (60.7%)
volts: 12.2 min: 10.9 model: IFIXIT bq20z451 type: Li-ion serial: N/A
status: charging cycles: 22
Info: model: Intel Core i7-2635QM bits: 64 type: MT MCP arch: Sandy Bridge
gen: core 2 level: v2 built: 2010-12 process: Intel 32nm family: 6
model-id: 0x2A (42) stepping: 7 microcode: 0x2F
Topology: cpus: 1x cores: 4 tpc: 2 threads: 8 smt: enabled cache:
L1: 256 KiB desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB desc: 4x256 KiB
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 931 high: 1454 min/max: 800/2900 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 947 2: 1052 3: 1454
4: 800 5: 800 6: 798 7: 800 8: 800 bogomips: 32001
Flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
Vulnerabilities:
Type: itlb_multihit status: KVM: VMX disabled
Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes, SMT
vulnerable
Type: mmio_stale_data status: Unknown: No mitigations
prctl
sanitization
STIBP: conditional, RSB filling, PBRSB-eIBRS: Not affected
Device-1: Intel 2nd Generation Core Processor Family Integrated Graphics
vendor: Apple driver: i915 v: kernel arch: Gen-6 process: Intel 32nm
built: 2011 ports: active: none off: LVDS-2 empty: DP-4,HDMI-A-1,VGA-1
bus-ID: 00:02.0 chip-ID: 8086:0116 class-ID: 0300
Device-2: AMD Seymour [Radeon HD 6400M/7400M Series] vendor: Apple
driver: radeon v: kernel alternate: amdgpu arch: TeraScale-2 code: Evergreen
process: TSMC 32-40nm built: 2009-15 pcie: gen: 2 speed: 5 GT/s lanes: 8
link-max: lanes: 16 ports: active: LVDS-1 empty: DP-1,DP-2,DP-3
bus-ID: 01:00.0 chip-ID: 1002:6760 class-ID: 0300
Device-3: Apple FaceTime HD Camera type: USB driver: uvcvideo
bus-ID: 1-2:3 chip-ID: 05ac:8509 class-ID: 0e02 serial:
Display: x11 server: X.Org v: 1.20.14 with: Xwayland v: 22.1.5
compositor: gnome-shell driver: X: loaded: modesetting,radeon
unloaded: fbdev,vesa dri: r600 gpu: i915,radeon display-ID: :1 screens: 1
Screen-1: 0 s-res: 1680x1050 s-dpi: 96 s-size: 444x277mm (17.48x10.91")
s-diag: 523mm (20.6")
Monitor-1: LVDS-1 mapped: LVDS pos: primary model: Apple Color LCD
built: 2009 res: 1680x1050 hz: 60 dpi: 129 gamma: 1.2
size: 331x207mm (13.03x8.15") diag: 390mm (15.4") ratio: 16:10 modes:
max: 1680x1050 min: 640x480
Monitor-2: LVDS-2 mapped: LVDS-1-2 note: disabled model: Apple Color LCD
built: 2009 res: 1680x1050 dpi: 129 gamma: 1.2 size: 331x207mm (13.03x8.15")
diag: 390mm (15.4") ratio: 16:10 modes: 1680x1050
API: OpenGL v: 3.3 Mesa 22.1.7 renderer: AMD CAICOS (DRM 2.50.0 /
6.0.9-200.fc36.x86_64 LLVM 14.0.0) compat-v: 3.1 direct render: Yes
Device-1: Intel 6 Series/C200 Series Family High Definition Audio
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:1c20
class-ID: 0403
Device-2: AMD Caicos HDMI Audio [Radeon HD 6450 / 7450/8450/8490 OEM R5
230/235/235X OEM] driver: snd_hda_intel v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 8 link-max: lanes: 16 bus-ID: 01:00.1
chip-ID: 1002:aa98 class-ID: 0403
Sound API: ALSA v: k6.0.9-200.fc36.x86_64 running: yes
Sound Server-1: PulseAudio v: 15.0 running: no
Sound Server-2: PipeWire v: 0.3.60 running: yes
Device-1: Broadcom NetXtreme BCM57765 Gigabit Ethernet PCIe driver: tg3
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: N/A bus-ID: 02:00.0
chip-ID: 14e4:16b4 class-ID: 0200
IF: enp2s0f0 state: down mac:
Device-2: Broadcom BCM4331 802.11a/b/g/n vendor: Apple AirPort Extreme
driver: wl v: kernel modules: bcma pcie: gen: 1 speed: 2.5 GT/s lanes: 1
bus-ID: 03:00.0 chip-ID: 14e4:4331 class-ID: 0280
IF: wlp3s0 state: up mac:
Bluetooth:
Device-1: Apple Bluetooth Host Controller type: USB driver: btusb v: 0.8
bus-ID: 1-1.1.3:8 chip-ID: 05ac:821a class-ID: fe01
Report: rfkill ID: hci0 rfk-id: 0 state: down bt-service: enabled,running
Local Storage: total: 894.25 GiB used: 87.53 GiB (9.8%)
SMART Message: Required tool smartctl not installed. Check --recommends
ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT960BX500SSD1
size: 894.25 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: rev: R022 scheme: GPT
ID-1: / raw-size: 95.3 GiB size: 95.3 GiB (100.00%) used: 35.09 GiB (36.8%)
fs: btrfs dev: /dev/sda6 maj-min: 8:6
ID-2: /boot raw-size: 1024 MiB size: 973.4 MiB (95.06%)
used: 264.5 MiB (27.2%) fs: ext4 dev: /dev/sda5 maj-min: 8:5
ID-3: /boot/efi raw-size: 600 MiB size: 600 MiB (100.00%)
used: 34.7 MiB (5.8%) fs: hfsplus dev: /dev/sda4 maj-min: 8:4
ID-4: /home raw-size: 95.3 GiB size: 95.3 GiB (100.00%)
used: 35.09 GiB (36.8%) fs: btrfs dev: /dev/sda6 maj-min: 8:6
Kernel: swappiness: 60 (default) cache-pressure: 100 (default)
ID-1: swap-1 type: zram size: 3.83 GiB used: 0 KiB (0.0%) priority: 100
dev: /dev/zram0
System Temperatures: cpu: 52.0 C mobo: 0.0 C
Fan Speeds (RPM): N/A
Processes: 330 Uptime: 4m wakeups: 2 Memory: 7.67 GiB used: 1.4 GiB (18.3%)
Init: systemd v: 250 target: graphical (5) default: graphical
tool: systemctl Compilers: gcc: 12.2.1 Packages: pm: rpm pkgs: N/A
note: see --rpm tools: dnf,yum pm: flatpak pkgs: 22 Shell: Bash v: 5.2.9
running-in: gnome-terminal inxi: 3.3.23
If you wish for anything else, please let me know. This installation keeps running since this last June '22 without any issues. Even had Fedora Rawhide running for some weeks, before returning back to Fedora 36 by an OS downgrade.
The only thing I remember of the initial install I had to do was installing the broadcom-wl package, to get my wifi working. All else keeps running OOTB on Fedora 36. No TLPUI needed, only mbpfan configured against too much overheating by only defining minimum fan speeds (3500RPM for both, left and right fan seems to suffice even under load).
I still have Rawhide running on my old iMac (2009) and it works ok there. Even though that machine is more troublesome in comparison to the MBP, due to more hw limitations.
What might be of some relevance here, to the OP might be this part-snippet from my inxi -Fza above:
This seems to show that Fedora is able to ignore the internal graphics by itself, and simply use the dedicated one? Correct me, if I’m wrong here, please @manuel.
Internal:
Intel HD Graphics 3000, 384 MB shared
Dedicated:
AMD Radeon HD 6490M, 256 MB
:wink:
inxi-Fza
Kernel: 5.19.0-23-generic arch: x86_64 bits: 64 compiler: N/A
parameters: BOOT_IMAGE=/boot/vmlinuz-5.19.0-23-generic
root=UUID=6625df43-851b-4a9a-90c2-47cad8b8323c ro quiet splash
vt.handoff=7
Desktop: GNOME v: 43.0 tk: GTK v: 3.24.34 wm: gnome-shell dm: GDM3
v: 43.0 Distro: Ubuntu 22.10 (Kinetic Kudu)
Type: Laptop System: Apple product: MacBookPro8,3 v: 1.0
serial: Chassis: type: 10 v: Mac-942459F5819B171B
serial:
Mobo: Apple model: Mac-942459F5819B171B v: MacBookPro8,3
serial: UEFI: Apple v: MBP81.88Z.0050.B00.1804101331
date: 04/10/18
Battery:
ID-1: BAT0 charge: 6.6 Wh (9.3%) condition: 70.7/76.3 Wh (92.7%)
volts: 11.0 min: 10.9 model: SMP A1383 type: Li-ion serial: N/A
status: charging cycles: 8
Info: model: Intel Core i7-2820QM bits: 64 type: MT MCP arch: Sandy Bridge
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 2637 high: 2960 min/max: 800/3400 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 2952 2: 800 3: 2960
4: 2920 5: 2955 6: 2811 7: 2833 8: 2869 bogomips: 36798
Vulnerabilities:
vulnerable
prctl
sanitization
built: 2011 ports: active: LVDS-1 empty: DP-1,HDMI-A-1,VGA-1
bus-ID: 00:02.0 chip-ID: 8086:0126 class-ID: 0300
Device-2: AMD Whistler [Radeon HD 6630M/6650M/6750M/7670M/7690M]
vendor: Apple driver: radeon v: kernel alternate: amdgpu arch: TeraScale-2
code: Evergreen process: TSMC 32-40nm built: 2009-15 pcie: gen: 2
speed: 5 GT/s lanes: 8 link-max: lanes: 16 ports: active: LVDS-2
empty: DP-2,DP-3,DP-4 bus-ID: 01:00.0 chip-ID: 1002:6741 class-ID: 0300
Display: wayland server: X.org v: 1.21.1.4 with: Xwayland v: 22.1.3
compositor: gnome-shell driver: gpu: i915,radeon display-ID: 0
Monitor-1: LVDS-1 model: Apple 0x9cce built: 2009 res: 1920x1200 dpi: 133
gamma: 1.2 size: 367x230mm (14.45x9.06") diag: 433mm (17.1") ratio: 16:10
modes: 1920x1200
Monitor-2: LVDS-2 model: Apple 0x9cce built: 2009 res: 1920x1200 dpi: 133
modes: max: 1920x1200 min: 640x480
OpenGL: renderer: AMD TURKS (DRM 2.50.0 / 5.19.0-23-generic LLVM 15.0.2)
v: 3.3 Mesa 22.2.1 compat-v: 3.1 direct render: Yes
class-ID: 0403
Device-2: AMD Turks HDMI Audio [Radeon HD 6500/6600 / 6700M Series]
driver: snd_hda_intel v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 8
link-max: lanes: 16 bus-ID: 01:00.1 chip-ID: 1002:aa90 class-ID: 0403
Sound Server-1: ALSA v: k5.19.0-23-generic running: yes
Sound Server-2: PipeWire v: 0.3.58 running: yes
IF: enp2s0 state: down mac:
Bluetooth:
Report: hciconfig ID: hci0 rfk-id: 2 state: up address:
bt-v: 1.2 lmp-v: 2.1 sub-v: 422a hci-v: 2.1 rev: 34f
Info: acl-mtu: 1021:8 sco-mtu: 64:1 link-policy: rswitch hold sniff park
link-mode: peripheral accept service-classes: rendering, capturing, audio,
telephony
Local Storage: total: 447.13 GiB used: 73.53 GiB (16.4%)
ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: SA400S37480G
size: 447.13 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: rev: J4.3 scheme: GPT
ID-1: / raw-size: 446.63 GiB size: 438.55 GiB (98.19%) used: 73.53 GiB
(16.8%) fs: ext4 dev: /dev/sda2 maj-min: 8:2
ID-2: /boot/efi raw-size: 512 MiB size: 511 MiB (99.80%) used: 5.2 MiB
(1.0%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-1: swap-1 type: file size: 2 GiB used: 284.5 MiB (13.9%) priority: -2
file: /swapfile
System Temperatures: cpu: 84.0 C mobo: 0.0 C
Processes: 333 Uptime: 14m wakeups: 2 Memory: 7.68 GiB used: 4.62 GiB
(60.2%) Init: systemd v: 251 target: graphical (5) default: graphical
tool: systemctl Compilers: gcc: 12.2.0 alt: 12 Packages: 2159 pm: dpkg
pkgs: 2122 libs: 1168 tools: apt,apt-get,gnome-software pm: flatpak
pkgs: 13 pm: snap pkgs: 24 Shell: Bash v: 5.2.2 running-in: gnome-terminal
inxi: 3.3.21
So it must have to do with Arch Linux kernels. My long-held suspicion, because neither Arch, nor EnOS do boot on our machines…
Might be so. Maybe fedora is explicitly blacklisting i915? It looks like using radeon.
Anyway, that might work for users with this kind of machine. Maybe with the LTS kernel?
no sure this help . early 13" 2011 Macbook Pro just integrated graphic
Summary
[shjim@arch-linux ~]$ inxi -Fza
Kernel: 6.0.10-arch2-1 arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-linux
root=UUID=9b5f847f-85ce-448c-b466-2fdb56dac2a8 rw loglevel=3 quiet
Desktop: GNOME v: 43.1 tk: GTK v: 3.24.35 wm: gnome-shell dm: GDM v: 43.0
Distro: Arch Linux
Type: Laptop System: Apple product: MacBookPro8,1 v: 1.0
serial: Chassis: type: 10 v: Mac-94245B3640C91C81
serial:
Mobo: Apple model: Mac-94245B3640C91C81 v: MacBookPro8,1
date: 04/10/18
Battery:
ID-1: BAT0 charge: 37.8 Wh (68.5%) condition: 55.2/62.9 Wh (87.8%)
volts: 11.3 min: 10.9 model: SMP bq20z451 type: Li-ion serial: N/A
status: discharging cycles: 111
Info: model: Intel Core i7-2620M bits: 64 type: MT MCP arch: Sandy Bridge
Topology: cpus: 1x cores: 2 tpc: 2 threads: 4 smt: enabled cache:
L1: 128 KiB desc: d-2x32 KiB; i-2x32 KiB L2: 512 KiB desc: 2x256 KiB
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 798 min/max: 800/3400 scaling: driver: intel_cpufreq
governor: powersave cores: 1: 798 2: 798 3: 798 4: 798 bogomips: 21561
Vulnerabilities:
vulnerable
prctl
sanitization
built: 2011 ports: active: LVDS-1 empty: DP-1, DP-2, DP-3, HDMI-A-1,
HDMI-A-2, HDMI-A-3, VGA-1 bus-ID: 00:02.0 chip-ID: 8086:0126
class-ID: 0300
Device-2: Apple FaceTime HD Camera type: USB driver: uvcvideo
Display: wayland server: X.org v: 1.21.1.4 with: Xwayland v: 22.1.5
alternate: fbdev,intel,vesa dri: crocus gpu: i915 display-ID: 0
Monitor-1: LVDS-1 model: Apple Color LCD built: 2009 res: 1280x800
dpi: 114 gamma: 1.2 size: 286x179mm (11.26x7.05") diag: 337mm (13.3")
ratio: 16:10 modes: 1280x800
API: EGL/GBM Message: No known Wayland EGL/GBM data sources.
class-ID: 0403
Sound API: ALSA v: k6.0.10-arch2-1 running: yes
Sound Server-1: JACK v: 1.9.21 running: no
Sound Server-2: PulseAudio v: 16.1 running: no
Sound Server-3: PipeWire v: 0.3.60 running: yes
Bluetooth:
Device-1: Apple Bluetooth USB Host Controller type: USB driver: btusb v: 0.8
bus-ID: 1-1.1.3:8 chip-ID: 05ac:821d class-ID: fe01
Report: rfkill ID: hci0 rfk-id: 0 state: up address: see --recommends
Local Storage: total: 2.27 TiB used: 87.76 GiB (3.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 500GB
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: rev: 4B6Q scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Toshiba model: HDWL120 size: 1.82 TiB
block-size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s type: HDD
rpm: 5400 serial: rev: 0A scheme: GPT
ID-1: / raw-size: 60 GiB size: 58.76 GiB (97.93%) used: 23.18 GiB (39.4%)
ID-2: /home raw-size: 405.27 GiB size: 397.84 GiB (98.17%)
used: 64.58 GiB (16.2%) fs: ext4 dev: /dev/sda3 maj-min: 8:3
Processes: 218 Uptime: 2m wakeups: 9 Memory: 15.54 GiB used: 1.18 GiB (7.6%)
Init: systemd v: 252 default: graphical tool: systemctl Compilers:
gcc: 12.2.0 Packages: pm: pacman pkgs: 1069 libs: 261 tools: yay pm: flatpak
pkgs: 0 Shell: Bash v: 5.1.16 running-in: xfce4-terminal inxi: 3.3.23
