Wouldn’t it be better to use --removable in this case? Using --no-nvram will leave you with an unbootable system I think. --removable will write the default UEFI entry so the system can boot.
--no-nvram is more for subsequent installs where there is already a valid entry in nvram.
could be i am not sure here at all… as it looks like NVRAM is not writable at all … and it only boot on
No BootOrder is set; firmware will attempt recovery
all together.
but yes --removable is the better option to use for newly install a system …
I do still think it is the nvram that needs to get rewritten/reset by try to reflash the firmware/bios.
The other question would be if it shows any boot entries when booting or inside the firmware interface ?
I saw people where it show the same output for efibootmgr but there were entries in the nvram that you can choose on boot…
On the other NUC where I managed to install an encrypted EOS Qtile along with a not encrypted Lubuntu (for guests) I have :
[crocefisso@crocefisso-pc ~]$ sudo efibootmgr -v -v
[sudo] Mot de passe de crocefisso :
Could not read variable 'BootNext': No such file or directory
error trace:
efivarfs.c:268 efivarfs_get_variable(): open(/sys/firmware/efi/efivars/BootNext-8be4df61-93ca-11d2-aa0d-00e098032b8c): No such file or directory
lib.c:140 efi_get_variable(): ops->get_variable failed: No such file or directory
Could not read variable 'BootCurrent': No such file or directory
error trace:
efivarfs.c:268 efivarfs_get_variable(): open(/sys/firmware/efi/efivars/BootCurrent-8be4df61-93ca-11d2-aa0d-00e098032b8c): No such file or directory
Could not read variable 'Timeout': No such file or directory
error trace:
efivarfs.c:268 efivarfs_get_variable(): open(/sys/firmware/efi/efivars/Timeout-8be4df61-93ca-11d2-aa0d-00e098032b8c): No such file or directory
Could not read variable 'BootOrder': No such file or directory
error trace:
efivarfs.c:268 efivarfs_get_variable(): open(/sys/firmware/efi/efivars/BootOrder-8be4df61-93ca-11d2-aa0d-00e098032b8c): No such file or directory
efibootmgr.c:372 read_order(): efi_get_variable failed: No such file or directory
Could not read variable 'MirrorCurrent': No such file or directory
error trace:
efivarfs.c:268 efivarfs_get_variable(): open(/sys/firmware/efi/efivars/MirrorCurrent-7b9be2e0-e28a-4197-ad3e-32f062f9462c): No such file or directory
Could not read variable 'MirrorRequest': No such file or directory
error trace:
efivarfs.c:268 efivarfs_get_variable(): open(/sys/firmware/efi/efivars/MirrorRequest-7b9be2e0-e28a-4197-ad3e-32f062f9462c): No such file or directory
However, I don’t think that the issue is coming from firmware, because I just tried to install EOS on my laptop (Acer Swift 3 SF314-54) and it failed with the same issue.
I managed to install an unencrypted EOS XFCE for guests. But when I try to install an encrypted EOS Gnome for myself, it fails.
I think the issue comes from wanting an encrypted EOS on a partition and an unencrypted EOS on the same machine (so the guests can boot the machine without any passphrase).
That doesn’t require any special configuration. It should “just work”.
It is failing because you are trying to share a /boot partition between the two. If you want a separate, unencrypted /boot in the encrypted installation to avoid the grub decryption prompt, that is an option. However, the unencrypted install doesn’t need that.
Keep in mind, in a UEFI installation, the EFI partition is where the bootloader is being launched from, not /boot. By default, we don’t use a separate /boot at all.
If for some reason, you want a separate /boot for both installations, that is fine as well. Just create two partitions, one for each installation.
Sorry, I think my GNU/Linux knowledge is too limited to fully understand. I’m trying to install EOS Gnome on /dev/sda3 as you can see in this picutre.
If I don’t need to create another partition, what shall I do not to have the EOS Gnome installation fail?
If I need to create another partition to install EOS Gnome, could you provide me with details on this partition (size, flag, mount point, system file)?
I managed to install EOS properly on my laptop, having /boot
on a specific partition (/dev/sda2) for the encrypted EOS (/dev/sda3)
on the same partition as the clear EOS (/dev/sda4)
Regarding the initial issue I had with my NUC, I changed Calamares script according to you prescription (see picture), but it didn’t worked. Installation failed, here is the log.
