The scanner works without problems.
This printer was working fine for me on Manjaro.
I don’t have problems installing it, as the computer detects it without any problem.
However when I print the test page it says this:
Procesando - "No se ha podido localizar la impresora "XRX9C934E46FB84.local"."
I’ve checked what is indicated in ‘Printers’ over discovery, and I don’t see where the problem could be.
The ping to the printer works without problems
Any idea what I should be looking for?
xircon
2
Firewall? Disable it, retry, if it works - renable and configure the firewall.
At work - no access to Linux machine, but home in a bit.
Check out this article, it covers network-printers and firewall, too.
https://discovery.endeavouros.com/printers/printers/2021/03/
I was able to install it as follows:
- Manual installation
- Choose the LPD/LPR option
- In the Connection indicate lpd://ip-printer/cola
system
Closed
5
