Incoming changes in JDK / JRE 21 packages may require manual intervention
Other package which have no problem have as dependency
Depends On      : java-environment
or
Depends On                    : java-runtime
elasticsearch has
Depends On                    : jre-openjdk-headless  libxml2
It is nicely documented here: https://wiki.archlinux.org/title/Java_package_guidelines#Dependencies
3.3 Dependencies
Java packages might specify java-runtime or java-environment as dependency, based on what they need.
For most packages, java-runtime is what is needed to simply run software written in Java.
java-environment (e.g. JDK) is needed by packages that will need to compile Java source code into bytecode.
See Java for more information.
That is exactly the problem. There are many out in AURs which set jdk-openjdk OR jre-openjdk(-headless) explicitly and that results in unsolveable conflicts. I will report to the maintainers for every package which is impacted. Thanks for testing!
This approach is what work for me. The others not.
sudo pacman -S jdk-openjdk
Endeavour ask to uninstall jre-openjdk Endeavour ask to uninstall jre-openjdk headless
Package (3) Old Version New Version Net Change Download Size
jre-openjdk 21.u35-3 -0.58 MiB
jre-openjdk-headless 21.u35-3 -192.59 MiB
extra/jdk-openjdk 21.u35-3 21.u35-8 827.49 MiB 457.46 MiB
Total Download Size: 457.46 MiB
Total Installed Size: 1136.47 MiB
Net Upgrade Size: 634.32 MiB
:: Proceed with installation? [Y/n]
Perfect response, happen just like bax84 say.
Just saw, that the maintainer of elasticsearch has reacted promptly to your request.
Depends On                    : java-runtime  libxml2
This is a good sign and means that the maintainer cares about things. :smile:
Yes - he only can react if we give feedbacks. I am also a coder and I am always lucky about issue reports. Nobody can watch everything.
I have to admit that I don’t know how to find all packages which depend on a specifc other package (like jdk-openjdk or jre-openjdk).
Ah, I should probably watch these forums more often. I’ve got netbeans and intellij installed and wondered why I had conflicts when updating.
My fix: I removed netbeans and intellig, then both the JRE and JDK. I then Installed the new JDK (I think mine was v17 before the updates), then netbeans and intellij. All is working fine. To be honest, I always thought the dev kit contained the runtime anyway? It used to anyway (back in my Windows days :grimacing:)…
No experience myself, but I found [1]. Perhaps of use for you?
[1]
Thank you for this! I noticed the problem, but was procrastinating in fixing the conflict.
Thanks for the link. Not exactly what I want but at least this
pacman -Qi | grep -E 'Depends On|Name' | grep -B 1 -E 'Depends On.*PACKAGE_X.*' | \
grep Name | awk -F ':' '{print $2}'
this shows all installed packages which depend on PACKAGE
PACKAGE_X is an example of a package name. You have to replce PACKAGE_X with the name of the package you’re looking for.
Of course I did.
But what I wanted was to find all the packages in the ARCH and AUR repos which depend on PACKAGE_X, where PACKAGE_X is for example jdk-openjdk
Aah, ok. It seems I can replace pacman -Qi with pacman -Si
Oh, in the repos.
Well, you could use pacman -Sii jdk-openjdk for the repos. Off the top of my head I don’t know if there is an equivalent for the AUR.
EDIT - ha, we posted at the same time.
I don’t see any possibility to get this for all available AUR packages
You can use the REST-API to get those:
$ curl "https://aur.archlinux.org/rpc/v5/search/jdk-openjdk?by=depends"
It returns a JSON response with the findings. If you’re just interested in the names, use jq to extract those:
$ curl -s "https://aur.archlinux.org/rpc/v5/search/jdk-openjdk?by=depends" | jq -r '.results.[].Name'
For more info, see https://wiki.archlinux.org/title/Aurweb_RPC_interface
