Im using a thinkpad carbon with i5 cpu and iGPU. when the computer comes out of sleep, the bottom half of the screen keeps flickering. i found a solution and managed to implement it on popos. however i dont know how to implement the solution on EOS
Hi.
The title explains the issue. Its a kernel bug with certain models of intel cpus and can be fixed by adding a command to kernel.
I managed to edit kernel in popos and it fixed the issue. below is the command that i used.
kernelstub -a “i915.enable_psr=0”
However I havent figured out how to implement the same kernel fix on EOS. this is my first time doing anything with kernel. anyone here who could tell me how I can add the command on EOS?
Grub or systemd-boot?
systemd-boot - edit /etc/kernel/cmdline add i915.enable_psr=0
Rebuild your initramfs - sudo reinstall-kernels
Grub - edit /etc/default/grub e.g.
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash i915.enable_psr=0"
Rebuild initramfs - you will have to look this up - my memory is baaaaad :rofl:
You likely forget more than what I’ll ever know. :thinking:
Been on dracut for a while. It used to be easy - sudo update-grub but that was removed, think it is still in aur, but it is only an alias to the full command:
(I cheated - I ssh’d into my home pc from my phone!!!).
In the future, and on any forum, use shorter titles like, “Screen Flickering on Thinkpad Carbon” and put the details in the post.
Please. :pray:
hey. thank you. its systemmd. however I have a question. i believe this file is read only. how do i edit the file if it’s read only? :slight_smile:
sudo nano /path/file.name
