5.9. Tray padding
The tray is shown on the right-hand side of the bar. By default, a padding of 2 pixels is used for the upper, lower and right-hand side of the tray area and between the individual icons. Syntax:
tray_padding [px]
tray_padding 3 makes the nm and bluetooth icons just a little to small for old eye.
I am using padding 1 and increased the font on the bar to 14. That seems to give me enough contrast on the nm icon to see the little square box indicating my VPN is connected.
BTW Doktor, your tutorial on changing the Bluetooth icon color was much appreciated
If I may impose upon you for a little polybar assistance: is there a polybar config already in use in EOS somewhere that I could download? I find it a million times easier to start with someone else’s config and modify. The default with polybar requires way too much editing and reading that I don’t have time for right now. Thank you in advance.
