for showing “error, critical and alert priority messages” (journalctl) produces litteraly hundreds of lines that I am admittedly in need of assistance to interpret. If you could just skim through it and give some advice I’ll be most grateful.
Yes, that one attracted my attention too. Do you have some ideas how I could troubleshoot that? What are the consequence of this for the overall functioning the system? I mean, without having run the command line above, I wouldn’t have noticed anything at all. Everything seems to be running smoothly.
@dalto,
Is there any way to monitor what gets logged in the journals in real-time with journalctl or something else. Like what you get from dmesg -w for kernel messages.
By the way, I rebooted the system somewhat more than an hour ago and filtering the output from journalctl -p err..alert for the last boot shows only the following so far:
-- Journal begins at Sun 2021-08-08 10:36:04 CEST, ends at Mon 2021-08-09 22:55:10 CEST. --
Aug 09 21:35:50 enos-gnome kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.LPC0.EC0], AE_NOT_FOUND (20210331/dswload2-162)
Aug 09 21:35:50 enos-gnome kernel: ACPI Error: AE_NOT_FOUND, During name lookup/catalog (20210331/psobject-220)
Aug 09 21:35:50 enos-gnome systemd-udevd[475]: vboxdrv: /usr/lib/udev/rules.d/60-vboxdrv.rules:1 Only network interfaces can be renamed, ignoring NAME="vboxdrv".
Aug 09 21:35:50 enos-gnome systemd-udevd[466]: vboxdrvu: /usr/lib/udev/rules.d/60-vboxdrv.rules:2 Only network interfaces can be renamed, ignoring NAME="vboxdrvu".
Aug 09 21:35:50 enos-gnome systemd-udevd[468]: vboxnetctl: /usr/lib/udev/rules.d/60-vboxdrv.rules:3 Only network interfaces can be renamed, ignoring NAME="vboxnetctl".
Aug 09 21:35:50 enos-gnome systemd-udevd[522]: vboxdrv: /usr/lib/udev/rules.d/60-vboxdrv.rules:1 Only network interfaces can be renamed, ignoring NAME="vboxdrv".
Aug 09 21:35:50 enos-gnome systemd-udevd[503]: vboxnetctl: /usr/lib/udev/rules.d/60-vboxdrv.rules:3 Only network interfaces can be renamed, ignoring NAME="vboxnetctl".
Aug 09 21:35:50 enos-gnome systemd-udevd[502]: vboxdrvu: /usr/lib/udev/rules.d/60-vboxdrv.rules:2 Only network interfaces can be renamed, ignoring NAME="vboxdrvu".
Aug 09 21:35:50 enos-gnome kernel: acp_pdm_mach acp_pdm_mach.0: snd_soc_register_card(acp) failed: -517
Aug 09 21:35:51 enos-gnome systemd-udevd[487]: zram0: /etc/udev/rules.d/99-zram.rules:1 Failed to write ATTR{/sys/devices/virtual/block/zram0/disksize}, ignoring: Device or resource busy
Aug 09 21:36:05 enos-gnome gdm-password][1360]: gkr-pam: unable to locate daemon control file
Aug 09 21:36:08 enos-gnome systemd[1374]: Failed to start Application launched by gnome-session-binary.
Aug 09 21:36:09 enos-gnome gdm-launch-environment][985]: GLib-GObject: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
Aug 09 21:36:14 enos-gnome pulseaudio[1541]: org.freedesktop.DBus.Properties.Get /org/bluez/hci0/dev_C0_28_8D_92_DF_CF/sep1/fd0 Volume failed: org.freedesktop.DBus.Error.InvalidArgs: No such property 'Volume'
Aug 09 21:36:51 enos-gnome kernel: ucsi_acpi USBC000:00: PPM init failed (-110)
In the logs I postet in the OP, gnome-shell dumped core almost immediately after boot.
What does
mean? Does it mean that zram is not setup or functioning properly. I have had an unresolved issue to set up a combination of zram and regular swap partition on this system.
