It looks like you posted before your image finished uploading.
Fixed
Looks like your system may be in a partially updated state.
Try opening konsole and type yay
Also, be sure to always update your system before installing any software.
Great title and useful screen shot just kidding. Obviously you haven’t checked the forum help on top of the page. Here is good practice:
Also better to copy paste the output into code brackets then post the text here. So it is searchable and useful.
Btw welcome to the community I make fun of everything.
I cannot use anything on my desktop so I’ll have to type it all out on my phone.
Ok screen frozen? You can switch to tty then enter commands or fixes if needed. Like you would on the terminal.
https://wiki.archlinux.org/title/Linux_console
Something like Alt+F1
depending on your system
The screens not frozen I just cant access any of my applications.
Could you switch to TTY as mentioned before?
Try Ctrl-Alt-F3 or the like.
You can do any of the logs in a tty and add | eos-sendlog
to the end of it and it will create a link you can post to us, and that’s all you’ll have to type out on your phone.
I can access the console.
Have you tried updating the system from the console by typing yay
Yes several times and nothin.
What does pacman -Q icu
return?
Also, pacman -Q plasma-workspace
Icu 72.1-1
Plasma-workspace 5.26.1-2
Just to confirm, you have tried rebooting?
Yes several times
What is the output of sudo pacman -S plasma-workspace
It reinstalled it.
Were there any errors in the output?
If not, try rebooting.
