I got lots of dracut commands not found when updating the system
[baoqizhang@ga402xv ~]$ sudo pacman -Syu
[sudo] password for baoqizhang:
:: Synchronising package databases…
endeavouros is up to date
core is up to date
extra 8.3 MiB 5.11 MiB/s 00:02 [--------------------] 100%
multilib is up to date
archlinuxcn is up to date
:: Starting full system upgrade…
warning: onlyoffice-bin: local (7.5.1-1) is newer than archlinuxcn (7.5.0-1)
resolving dependencies…
looking for conflicting packages…
Package (1) Old Version New Version Net Change Download Size
extra/dracut 059-4 059-5 0.00 MiB 0.28 MiB
Total Download Size: 0.28 MiB
Total Installed Size: 1.02 MiB
Net Upgrade Size: 0.00 MiB
:: Proceed with installation? [Y/n]
:: Retrieving packages…
dracut-059-5-x86_64 287.9 KiB 281 KiB/s 00:01 [--------------------] 100%
(1/1) checking keys in keyring [--------------------] 100%
(1/1) checking package integrity [--------------------] 100%
(1/1) loading package files [--------------------] 100%
(1/1) checking for file conflicts [--------------------] 100%
:: Processing package changes…
(1/1) upgrading dracut [--------------------] 100%
New optional dependencies for dracut
tpm2-tools: tpm2 support for e.g. LUKS
:: Running post-transaction hooks…
(1/4) Reloading system manager configuration…
(2/4) Arming ConditionNeedsUpdate…
(3/4) Updating initramfs…
:: Building initramfs for linux (6.7.0-arch3-1)
dracut: Executing: /usr/bin/dracut --force --hostonly --no-hostonly-cmdline /boot/initramfs-linux.img 6.7.0-arch3-1
dracut: dracut module ‘dash’ will not be installed, because command ‘dash’ could not be found!
dracut: dracut module ‘mksh’ will not be installed, because command ‘mksh’ could not be found!
dracut: dracut module ‘systemd-pcrphase’ will not be installed, because command ‘/usr/lib/systemd/systemd-pcrphase’ could not be found!
dracut: dracut module ‘busybox’ will not be installed, because command ‘busybox’ could not be found!
dracut: dracut module ‘rngd’ will not be installed, because command ‘rngd’ could not be found!
dracut: dracut module ‘connman’ will not be installed, because command ‘connmand’ could not be found!
dracut: dracut module ‘connman’ will not be installed, because command ‘connmanctl’ could not be found!
dracut: dracut module ‘connman’ will not be installed, because command ‘connmand-wait-online’ could not be found!
dracut: dracut module ‘network-wicked’ will not be installed, because command ‘wicked’ could not be found!
dracut: dracut module ‘dmraid’ will not be installed, because command ‘kpartx’ could not be found!
dracut: dracut module ‘tpm2-tss’ will not be installed, because command ‘tpm2’ could not be found!
dracut: dracut module ‘iscsi’ will not be installed, because command ‘iscsi-iname’ could not be found!
dracut: dracut module ‘iscsi’ will not be installed, because command ‘iscsiadm’ could not be found!
dracut: dracut module ‘iscsi’ will not be installed, because command ‘iscsid’ could not be found!
dracut: dracut module ‘nvmf’ will not be installed, because command ‘nvme’ could not be found!
dracut: dracut module ‘biosdevname’ will not be installed, because command ‘biosdevname’ could not be found!
dracut: dracut module ‘memstrack’ will not be installed, because command ‘memstrack’ could not be found!
dracut: memstrack is not available
dracut: If you need to use rd.memdebug>=4, please install memstrack and procps-ng
dracut: dracut module ‘squash’ will not be installed, because command ‘mksquashfs’ could not be found!
dracut: dracut module ‘squash’ will not be installed, because command ‘unsquashfs’ could not be found!
dracut: *** Including module: systemd ***
dracut: *** Including module: systemd-initrd ***
dracut: *** Including module: i18n ***
dracut: *** Including module: kernel-modules ***
dracut: *** Including module: kernel-modules-extra ***
dracut: *** Including module: rootfs-block ***
dracut: *** Including module: terminfo ***
dracut: *** Including module: udev-rules ***
dracut: Skipping udev rule: 40-redhat.rules
dracut: Skipping udev rule: 50-firmware.rules
dracut: Skipping udev rule: 50-udev.rules
dracut: Skipping udev rule: 91-permissions.rules
dracut: Skipping udev rule: 80-drivers-modprobe.rules
dracut: Skipping udev rule: 70-persistent-net.rules
dracut: *** Including module: dracut-systemd ***
dracut: *** Including module: usrmount ***
dracut: *** Including module: base ***
dracut: *** Including module: fs-lib ***
dracut: *** Including module: shutdown ***
dracut: *** Including modules done ***
dracut: *** Installing kernel module dependencies ***
dracut: *** Installing kernel module dependencies done ***
dracut: *** Resolving executable dependencies ***
dracut: *** Resolving executable dependencies done ***
dracut: *** Hardlinking files ***
dracut: Mode: real
dracut: Method: sha256
dracut: Files: 815
dracut: Linked: 3 files
dracut: Compared: 0 xattrs
dracut: Compared: 35 files
dracut: Saved: 356.78 KiB
dracut: Duration: 0.003290 seconds
dracut: *** Hardlinking files done ***
dracut: *** Generating early-microcode cpio image ***
dracut: *** Constructing AuthenticAMD.bin ***
dracut: *** Store current command line parameters ***
dracut: *** Stripping files ***
dracut: *** Stripping files done ***
dracut: *** Creating image file ‘/boot/initramfs-linux.img’ ***
dracut: *** Creating initramfs image file ‘/boot/initramfs-linux.img’ done ***
:: Building fallback initramfs for linux (6.7.0-arch3-1)
dracut: Executing: /usr/bin/dracut --force --no-hostonly /boot/initramfs-linux-fallback.img 6.7.0-arch3-1
dracut: dracut module ‘multipath’ will not be installed, because command ‘multipath’ could not be found!
dracut: dracut module ‘fcoe’ will not be installed, because command ‘dcbtool’ could not be found!
dracut: dracut module ‘fcoe’ will not be installed, because command ‘fipvlan’ could not be found!
dracut: dracut module ‘fcoe’ will not be installed, because command ‘lldpad’ could not be found!
dracut: dracut module ‘fcoe’ will not be installed, because command ‘fcoemon’ could not be found!
dracut: dracut module ‘fcoe’ will not be installed, because command ‘fcoeadm’ could not be found!
dracut: dracut module ‘fcoe-uefi’ will not be installed, because command ‘dcbtool’ could not be found!
dracut: dracut module ‘fcoe-uefi’ will not be installed, because command ‘fipvlan’ could not be found!
dracut: dracut module ‘fcoe-uefi’ will not be installed, because command ‘lldpad’ could not be found!
dracut: *** Including module: modsign ***
dracut: *** Including module: btrfs ***
dracut: *** Including module: crypt ***
dracut: *** Including module: dm ***
dracut: Skipping udev rule: 64-device-mapper.rules
dracut: Skipping udev rule: 60-persistent-storage-dm.rules
dracut: Skipping udev rule: 55-dm.rules
dracut: *** Including module: lvm ***
dracut: Skipping udev rule: 56-lvm.rules
dracut: Skipping udev rule: 60-persistent-storage-lvm.rules
dracut: *** Including module: mdraid ***
dracut: Skipping udev rule: 64-md-raid.rules
dracut: *** Including module: nvdimm ***
dracut: *** Including module: qemu ***
dracut: *** Including module: qemu-net ***
dracut: *** Including module: btrfs-snapshot-overlay ***
dracut: *** Including module: lunmask ***
dracut: *** Including module: resume ***
dracut: *** Including module: virtiofs ***
dracut: Mode: real
dracut: Files: 2031
dracut: Linked: 9 files
dracut: Compared: 455 files
dracut: Saved: 1.42 MiB
dracut: Duration: 0.008176 seconds
dracut: *** Creating image file ‘/boot/initramfs-linux-fallback.img’ ***
dracut: *** Creating initramfs image file ‘/boot/initramfs-linux-fallback.img’ done ***
(4/4) Checking which packages need to be rebuilt
That is normal
you can disable those messages by following the Making dracut less verbose section here:
https://discovery.endeavouros.com/installation/dracut/2022/12/
alright, thanks!
