I cant seem to set a default resolution.I want it to to be 1920x1080 but it always returns to 800x600
I tried with a xrandr script, that wont work i don’t know what to do.
xrandr --output Virtual1 -mode 1920x10808
The xranr script works but you have to manually execute it every time you login.The grub bootloader is also of incorrect resolution.
Please Help
In addition to checking what @dalto mentioned above, try adding the following line to your ~/.config/i3/config, save the file and restart i3 to see if the resolution stays as it should:
this will be added per default in next release to be running.
On my testings i see that you need to use the fullscreen switcher from vmware menu twice to get it working, and it could be that for i3 you need to add the resolution to be applied like so:
using arandr tool and save the settings as monitor what will get saved as ~/.screenlayout/monitor.sh and used by eos i3 config to set display
It should have, I believe. It’s almost the same command you have been running but made to stick through the config file. Perhaps someone could correct me it I am wrong
Sorry anyways if it caused more trouble for you.
