I can’t connect to wifi. I see avaible networks that I can connect to but after I put password in it wont connect me.
I ran
ip link
and saw that my network adapter is down.
So I tried running
ip link set wlan0 up
but it didnt work.
When I tried to install Arch I ran into the same problem.
Can somebody help?
eso
2
Hello @Ojciec_Mateusz ,
nmtui
does not see your adapter?
It see avaible wifi networks but I cant connect to them
eso
4
nmtui / Activate ( and you recognize your wifi, selected it and)
asked for password or did not ?
Asked but after I put in password it just dosen’t connect.
What is your wifi hardware?
inxi -Na
Qualcomm Atheros QCA9377 802.llac
I was wanting to see the output to make sure it’s loading the proper module?
Edit: Should be ath10k
Does it show your SSID that you are trying to connect to?
I can see ssid of avaible networks
Yes…but is your own there to connect to.
Is your connection using wpa because it won’t work if it’s using wep. Are the router settings correct?
So it just won’t connect? No error messages? Password?
My network adapter wlan0 is down and I cant connect after putting password in
What does this show? post the url
sudo dmesg | eos-sendlog
It didnt showed up anything
