Hello EndeavourOS community! I switched lately to this OS and I’ve solved the majority of my issues, One of the left is my 2 graphics tablet are being detected but no input is going on, I have read some solutions here but none worked. here is some useful outputs:
➜ ~ pacman -Q | grep -A 0 -E “(linux|wacom|input)”
archlinux-keyring 20250929-1
lib32-util-linux 2.41.2-1
libinput 1.29.1-1
libwacom 2.16.1-1
linux 6.17.1.arch1-1
linux-api-headers 6.16-2
linux-firmware 20250917-1
linux-firmware-amdgpu 20250917-1
linux-firmware-atheros 20250917-1
linux-firmware-broadcom 20250917-1
linux-firmware-cirrus 20250917-1
linux-firmware-intel 20250917-1
linux-firmware-mediatek 20250917-1
linux-firmware-nvidia 20250917-1
linux-firmware-other 20250917-1
linux-firmware-radeon 20250917-1
linux-firmware-realtek 20250917-1
linux-firmware-whence 20250917-1
linux-headers 6.17.1.arch1-1
linux-lts 6.12.51-1
linux-lts-headers 6.12.51-1
util-linux 2.41.2-1
util-linux-libs 2.41.2-1
xf86-input-libinput 1.5.0-1
xf86-input-synaptics 1.10.0-1
xf86-input-wacom 1.2.3-1
xorg-xinput 1.6.4-2
➜ ~ inxi -Fxxc0z
Kernel: 6.12.51-1-lts arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
Desktop: GNOME v: 49.0 tk: GTK v: 3.24.51 wm: gnome-shell dm: GDM
Type: Laptop System: LENOVO product: 82JW v: Legion 5 15ACH6
serial: Chassis: type: 10 v: Legion 5 15ACH6
serial:
Mobo: LENOVO model: LNVNB161216 v: SDK0R32862 WIN
serial: part-nu: LENOVO_MT_82JW_BU_idea_FM_Legion 5
15ACH6 UEFI: LENOVO v: HHCN37WW date: 01/17/2024
Battery:
ID-1: BAT0 charge: 53.8 Wh (98%) condition: 54.9/60 Wh (91.5%) volts: 17.23
min: 15.36 model: Celxpert L20C4PC0 serial: charging:
status: not charging cycles: 115
Info: 8-core model: AMD Ryzen 7 5800H with Radeon Graphics bits: 64
type: MT MCP arch: Zen 3 rev: 0 cache: L1: 512 KiB L2: 4 MiB L3: 16 MiB
Speed (MHz): avg: 1100 min/max: 400/4463 boost: enabled cores: 1: 1100
2: 1100 3: 1100 4: 1100 5: 1100 6: 1100 7: 1100 8: 1100 9: 1100 10: 1100
11: 1100 12: 1100 13: 1100 14: 1100 15: 1100 16: 1100 bogomips: 102246
Flags-basic: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a
ssse3 svm
Device-1: NVIDIA GA107BM [GeForce RTX 3050 Ti Mobile] vendor: Lenovo
driver: nvidia v: 580.95.05 arch: Ampere pcie: speed: 2.5 GT/s lanes: 8
ports: active: HDMI-A-1 empty: DP-1,DP-2,eDP-1 bus-ID: 01:00.0
chip-ID: 10de:25e0
Device-2: Advanced Micro Devices [AMD/ATI] Cezanne [Radeon Vega Series /
Radeon Mobile Series] vendor: Lenovo driver: amdgpu v: kernel arch: GCN-5
pcie: speed: 8 GT/s lanes: 16 ports: active: eDP-2 empty: none
bus-ID: 06:00.0 chip-ID: 1002:1638 temp: 46.0 C
Display: wayland server: ``X.org`` v: 1.21.1.18 with: Xwayland v: 24.1.8
compositor: gnome-shell driver: gpu: amdgpu,nvidia,nvidia-nvswitch
display-ID: 0
Monitor-1: HDMI-A-1 model: Dell P1913S res: 1280x1024 dpi: 86
diag: 482mm (19")
Monitor-2: eDP-2 model: AU Optronics 0x5895 res: 1920x1080 dpi: 142
diag: 394mm (15.5")
API: EGL v: 1.5 platforms: device: 0 drv: nvidia device: 1 drv: radeonsi
device: 3 drv: swrast gbm: drv: kms_swrast surfaceless: drv: nvidia wayland:
drv: radeonsi x11: drv: radeonsi inactive: device-2
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: amd mesa v: 25.2.4-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon Graphics (radeonsi
renoir ACO DRM 3.61 6.12.51-1-lts) device-ID: 1002:1638 display-ID: :0.0
Info: Tools: api: eglinfo,glxinfo gpu: nvidia-settings,nvidia-smi
x11: xdpyinfo, xprop, xrandr
Device-1: NVIDIA GA107 High Definition Audio driver: snd_hda_intel v: kernel
pcie: speed: 8 GT/s lanes: 8 bus-ID: 01:00.1 chip-ID: 10de:2291
Device-2: Advanced Micro Devices [AMD] Audio Coprocessor vendor: Lenovo
driver: N/A pcie: speed: 8 GT/s lanes: 16 bus-ID: 06:00.5 chip-ID: 1022:15e2
Device-3: Advanced Micro Devices [AMD] Family 17h/19h/1ah HD Audio
vendor: Lenovo driver: snd_hda_intel v: kernel pcie: speed: 8 GT/s lanes: 16
bus-ID: 06:00.6 chip-ID: 1022:15e3
API: ALSA v: k6.12.51-1-lts status: kernel-api
Server-1: PipeWire v: 1.4.8 status: active with: 1: pipewire-pulse
4: pw-jack type: plugin
Device-1: Realtek RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet
vendor: Lenovo driver: r8169 v: kernel pcie: speed: 2.5 GT/s lanes: 1
port: 3000 bus-ID: 03:00.0 chip-ID: 10ec:8168
IF: eno1 state: up speed: 100 Mbps duplex: full mac:
Device-2: Realtek RTL8852AE 802.11ax PCIe Wireless Network Adapter
vendor: Lenovo driver: rtw89_8852ae v: kernel pcie: speed: 2.5 GT/s lanes: 1
port: 2000 bus-ID: 04:00.0 chip-ID: 10ec:8852
IF: wlan0 state: up mac:
Bluetooth:
Device-1: Realtek Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 1.0
speed: 12 Mb/s lanes: 1 bus-ID: 3-4:4 chip-ID: 0bda:4852
Report: btmgmt ID: hci0 rfk-id: 2 state: down bt-service: disabled
Local Storage: total: 715.41 GiB used: 106.18 GiB (14.8%)
ID-1: /dev/nvme0n1 vendor: SK Hynix model: BC501 HFM256GDJTNG-8310A
size: 238.47 GiB speed: 15.8 Gb/s lanes: 2 serial: temp: 38.9 C
ID-2: /dev/nvme1n1 vendor: SK Hynix model: HFS512GDE9X084N
size: 476.94 GiB speed: 31.6 Gb/s lanes: 4 serial: temp: 48.9 C
ID-1: / size: 231.7 GiB used: 105.33 GiB (45.5%) fs: ext4
dev: /dev/nvme0n1p2
ID-1: swap-1 type: file size: 512 MiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
System Temperatures: cpu: 57.2 C mobo: N/A gpu: amdgpu temp: 46.0 C
Fan Speeds (rpm): N/A
Memory: total: 16 GiB note: est. available: 13.5 GiB used: 4.12 GiB (30.5%)
Processes: 358 Power: uptime: 23m wakeups: 0 Init: systemd v: 258
default: graphical
Packages: 1024 pm: pacman pkgs: 1009 pm: flatpak pkgs: 15 Compilers:
gcc: 15.2.1 Shell: Zsh v: 5.9 running-in: kitty inxi: 3.3.39
I’m recovering from distro hopping and a prior system breakage so please bear with me.
Thank you!
