Hi,
I recently did a fresh EndeavourOS (Deepin) live install and the installer setup my system to use kwin as the WM, i also have another older install of EndeavourOS (Deepin) that has been upgraded but this is still running Mutter as the WM.
The Deepin window effects are not working for me with Mutter so i would like to update my older system to use kwin (as everything seems fine with the new install).
What is the process to switch Deepin from using Mutter to kwin ? i’ve looked around and cannot find any docs on it.
Thanks in advance!
