Preface
This post describes a simple way of using the EndeavourOS ISO file as-is (i.e. without burning) for installing EndeavourOS.
Assumptions:
- You already have a working EndeavourOS install on the machine. Probably other distros work as well, but I’ve tested this idea only with EndeavourOS.
- You’ll need another drive, e.g. a USB stick.
The problem
Sometimes you may have a reason to install another instance of EndeavourOS onto one of your disks. But for some reason the normal procedure of burning the ISO to a USB stick has problems with your system.
For example, burning the ISO to a USB stick does not work, or the USB port(s) are not working, etc.
A solution
What you can do is actually quite simple:
- Copy (e.g. with
cp
, no burning needed!) the ISO file onto the root folder of another disk, e.g. a USB stick. - Write the following grub menu entry into file
/boot/grub/custom.cfg
as root user:
menuentry 'ISO - EndeavourOS Atlantis neo' {
set isofile=/EndeavourOS_Atlantis_neo-21_5.iso
search --no-floppy --set=root --file $isofile
probe -u $root --set=uuid
loopback loop $isofile
linux (loop)/arch/boot/x86_64/vmlinuz-linux img_dev=/dev/disk/by-uuid/$uuid img_loop=$isofile
initrd (loop)/arch/boot/intel-ucode.img (loop)/arch/boot/x86_64/initramfs-linux.img
That’s mostly it!
Then simply reboot and see the new grub menu entry for the ISO!
Additional notes
- If the name of the ISO file is different, modify the grub entry (the second line) accordingly.
- This entry does not work with all older EndeavourOS ISOs, because they have a slightly different organization of the files inside the ISO.
- I’ve tested this only on my few machines, so it is not guaranteed to work in every machine.
EDIT after 3h: some more additional notes:
- An ISO can boot this way for maintenance purposes as well.
- Note that installing to the same disk where booting occurred may not work.
