@ricklinux maybe make it a wiki post so they can edit it there?
Not sure how to do that.
When the system boots it still shows no device for hibernation.
Click the title of the first post, click the three dots at the bottom, click the wrench, and it will open a sub menu with the selection make wiki.
Then it still has to be edited. I thought there already was a wiki for this tutorial? Hmm? I didn’t get any training @Bryanpwo
@2000
I feel dumb now! Am i missing something? Like fstab? It reports no resume device for hibernation or something like that on boot.
[ricklinux@eos-cinnamon ~]$ cat /etc/fstab
# <file system> <mount point> <type> <options> <dump> <pass>
UUID=6B70-A3D2 /boot/efi vfat umask=0077 0 2
/dev/mapper/luks-c2711aa5-335d-45c6-ad4a-613eecc21422 / btrfs subvol=@,defaults,noatime,space_cache,autodefrag,compress=zstd,compress=zstd 0 0
/dev/mapper/luks-c2711aa5-335d-45c6-ad4a-613eecc21422 /home btrfs subvol=@home,defaults,noatime,space_cache,autodefrag,compress=zstd,compress=zstd 0 0
tmpfs /tmp tmpfs defaults,noatime,mode=1777 0 0
/dev/mapper/luks-c2711aa5-335d-45c6-ad4a-613eecc21422 /var/cache/pacman/pkg btrfs subvol=@var-cache-pacman-pkg,defaults,noatime,space_cache,autodefrag,compress=zstd,compress=zstd 0 0
/dev/mapper/luks-c2711aa5-335d-45c6-ad4a-613eecc21422 /swap btrfs subvol=@swap,defaults,compress=no 0 0
/swap/swapfile none swap defaults 0 0
We don\t use that part of the forum software. It is a wiki article, but if it needs editing then @2000 is the one to do it.
He said it wouldn’t work so i’m not sure what is the problem.
@2000
It say’s in fstab no swap file? But it shows:
[ricklinux@eos-cinnamon ~]$ swapon --show
NAME TYPE SIZE USED PRIO
/swap/swapfile file 8G 0B -2
May this be due to fallocate vs. dd?
Your fstab seems to be correct.
I’m somewhat stumped at this point; only thing I can think of atm is recreating the whole swapfile.
sudo swapoff
sudo rm /swap/swapfile
sudo truncate -s 0 /swap/swapfile
sudo chattr +C /swap/swapfile
sudo btrfs property set /swap/swapfile compression none
sudo fallocate -l 8G /swap/swapfile
sudo chmod 600 /swap/swapfile
sudo mkswap /swap/swapfile
sudo swapon /swap/swapfile
I’ve been reading about some troubles with swapfile creation with fallocate; as an alternative you could try dd instead
dd if=/dev/zero of=/swap/swapfile bs=1 count=0 seek=8G
[Edit: csteinforth had the same idea,
You would then have to get the new resume-offset value and adjust /etc/default/grub accordingly; followed by sudo grub-mkconfig -o /boot/grub/grub.cfg
@2000 maybe we had the same thougt.
Strange? First command say’s bad usage? So maybe there is no swap as it shows in fstab even though it shows otherwise with the command. Not even sure i’m doing it right. (Wrong command?)
swapon --show?
Just ignore the swapoff error.
Each command is just giving errors?
Is /swap listed if you run … ?
findmnt -nt btrfs
[ricklinux@eos-cinnamon ~]$ ls /swap
swapfile
[ricklinux@eos-cinnamon ~]$ findmnt -nt btrfs
/ /dev/mapper/luks-c2711aa5-335d-45c6-ad4a-613eecc21422[/@] btrfs rw,noat
├─/run/timeshift/backup
│ /dev/mapper/luks-c2711aa5-335d-45c6-ad4a-613eecc21422 btrfs rw,rela
├─/home
│ /dev/mapper/luks-c2711aa5-335d-45c6-ad4a-613eecc21422[/@home]
│ btrfs rw,noat
├─/swap
│ /dev/mapper/luks-c2711aa5-335d-45c6-ad4a-613eecc21422[/@swap]
│ btrfs rw,rela
└─/var/cache/pacman/pkg
/dev/mapper/luks-c2711aa5-335d-45c6-ad4a-613eecc21422[/@var-cache-pacman-pkg]
btrfs rw,noat
@2000
Why does it say in the fstab swap file none?
Edit: Maybe the None is just something under a column?
OK, /swap is an active subvolume, so you should be able to create a swapfile here. One problem less.
This is the mount directory; in the case of swap “none” is correct. See ArchWiki.
You really should be able to create a swapfile with the below commands. (?)
sudo dd if=/dev/zero of=/swap/swapfile bs=1 count=0 seek=8G
Something is stopping it?
[ricklinux@eos-cinnamon ~]$ sudo truncate -s 0 /swap/swapfile
[sudo] password for ricklinux:
truncate: failed to truncate '/swap/swapfile' at 0 bytes: Text file busy
I’ll try a restart and see.
