Also, this is the snapshot location for snapper.
I tried the " Timeshift >= version 22.06" instructions first:
sudo systemctl edit --full grub-btrfsd
[Unit]
Description=Regenerate grub-btrfs.cfg
[Service]
Type=simple
LogLevelMax=notice
# Set the possible paths for `grub-mkconfig`
Environment="PATH=/sbin:/bin:/usr/sbin:/usr/bin"
# Load environment variables from the configuration
EnvironmentFile=/etc/default/grub-btrfs/config
# Start the daemon, usage of it is:
# grub-btrfsd [-h, --help] [-t, --timeshift-auto] [-l, --log-file LOG_FILE] SNAPSHOTS_DIR
# SNAPSHOTS_DIR Snapshot directory to watch, without effect when --timeshift-auto
# Optional arguments:
# -t, --timeshift-auto Automatically detect Timeshifts snapshot directory
# -l, --log-file Specify a logfile to write to
# -v, --verbose Let the log of the daemon be more verbose
# -s, --syslog Write to syslog
ExecStart=/usr/bin/grub-btrfsd --syslog --timeshift-auto
[Install]
WantedBy=multi-user.target
sudo systemctl restart grub-btrfsd
And then testing, snapshotting, rebooting, a few times. Same result, didnāt work.
Is this something?
systemctl status grub-btrfs:
[vlad@endeavouros ~]$ systemctl status grub-btrfs
Unit grub-btrfs.service could not be found.
I then retried the steps
sudo systemctl start grub-btrfsd
sudo systemctl enable grub-btrfsd
And then again
which again gives the output
Oh I forgot it was a daemon:
ps -ef | grep grub.btrfs
gives the output
[vlad@endeavouros ~]$ ps -ef | grep grub.btrfs
vlad 2174 2087 0 15:31 pts/0 00:00:00 grep grub.btrfs
There is a typo. Should be: grub-btrfsd
Could you try the manual way of creating entries for the snapshots as described in the instructions from Github?
So to generate snapshot entries in the sub menu it is usually enough to run only the script with
sudo /etc/grub.d/41_snapshots-btrfs
systemctl status grub-btrfsd
[vlad@endeavouros ~]$ systemctl status grub-btrfsd
Ć grub-btrfsd.service - Regenerate grub-btrfs.cfg
Loaded: loaded (/etc/systemd/system/grub-btrfsd.service; enabled; preset: disabled)
Active: failed (Result: exit-code) since Tue 2023-01-03 15:21:56 CET; 12min ago
Duration: 25ms
Main PID: 2101 (code=exited, status=1/FAILURE)
CPU: 22ms
jan. 03 15:21:56 endeavouros grub-btrfsd[2102]: [!] inotifywait was not found, exiting. Is inotify-tools inst>
jan. 03 15:21:56 endeavouros systemd[1]: grub-btrfsd.service: Main process exited, code=exited, status=1/FAIL>
jan. 03 15:21:56 endeavouros systemd[1]: grub-btrfsd.service: Failed with result 'exit-code'.
lines 1-10/10 (END)
Install inotify-tools and try restarting the daemon.
OK, i tried
Then deleted all my snapshots, and created a single one ātest1ā.
then rebooted to grub, it still shows the same handful snapshots I had from last i rebuilt it manually.
Try this.
Also, I think
should be run after you create a new snaphot.
Yes, this was the step suggested by the IT professor I linked to earlier. I tried it then, and it didnāt work for me. Iād prefer a ānativeā solution anyway.
Iāll try again:
sudo pacman -S inotify-tools
Created another snapshot ātest2ā, rebooted. Same results, also when creating new snapshots and rebooting again. Same old non-existent snapshots show up in grub, it has not been rebuilt.
After installing inotify-tools and restarting the daemon, could you post again:
ā grub-btrfsd.service - Regenerate grub-btrfs.cfg
Active: active (running) since Tue 2023-01-03 15:45:09 CET; 4min 21s ago
Main PID: 502 (grub-btrfsd)
Tasks: 2 (limit: 4532)
Memory: 3.0M
CPU: 24ms
CGroup: /system.slice/grub-btrfsd.service
āā502 /bin/sh /usr/bin/grub-btrfsd --syslog --timeshift-auto
āā609 inotifywait -q -q -e create -e delete /run/timeshift
jan. 03 15:45:10 endeavouros grub-btrfsd[608]: Watching /run/timeshift for timeshift to start
At least it is running now.
Donāt really know why it wonāt add the snapshotās boot entries to grub?
Now that the daemon is running, as a last test, could you delete each and all snapshots, create a new one and then post your grub-btrfs.cfg?
Edit: correction grub.cfg >> grub-btrfs.cfg
You mean like this?
[vlad@endeavouros ~]$ systemctl cat grub-btrfsd
# /etc/systemd/system/grub-btrfsd.service
[Unit]
[Service]
Type=simple
LogLevelMax=notice
[Install]
Since I am not using grub-btrfs so I am guessing that the file might be in /boot/grub or thereabout ![]()
OK, grub-btrfs.cfg in /boot/grub:
menuentry '| Date | Snapshot | Type |Description|' { echo }
submenu '| 2023-01-03 16:00:01 | timeshift-btrfs/snapshots/2023-01-03_16-00-01/@ | daily weekly | N/A |' {
submenu '| 2023-01-03 16:00:01 | timeshift-btrfs/snapshots/2023-01-03_16-00-01/@ | daily weekly | N/A |' { echo }
menuentry ' vmlinuz-linux & initramfs-linux-fallback.img & intel-ucode.img' --class snapshots --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-snapshots-7f6441da-512e-46ad-8c4e-9837a70421a6' {
if [ x$feature_all_video_module = xy ]; then
insmod all_video
fi
set gfxpayload=keep
insmod btrfs
if [ x$feature_platform_search_hint = xy ]; then
search --no-floppy --fs-uuid --set=root --hint-bios=hd0,gpt2 --hint-efi=hd0,gpt2 --hint-baremetal=ahci0,gpt2 7f6441da-512e-46ad-8c4e-9837a70421a6
else
search --no-floppy --fs-uuid --set=root 7f6441da-512e-46ad-8c4e-9837a70421a6
fi
echo 'Loading Snapshot: 2023-01-03 16:00:01 timeshift-btrfs/snapshots/2023-01-03_16-00-01/@'
echo 'Loading Kernel: vmlinuz-linux ...'
linux "/timeshift-btrfs/snapshots/2023-01-03_16-00-01/@/boot/vmlinuz-linux" root=UUID=7f6441da-512e-46ad-8c4e-9837a70421a6 nowatchdog nvme_load=YES loglevel=3 rootflags=defaults,noatime,compress=zstd,subvol="timeshift-btrfs/snapshots/2023-01-03_16-00-01/@"
echo 'Loading Microcode & Initramfs: intel-ucode.img initramfs-linux-fallback.img ...'
initrd "/timeshift-btrfs/snapshots/2023-01-03_16-00-01/@/boot/intel-ucode.img" "/timeshift-btrfs/snapshots/2023-01-03_16-00-01/@/boot/initramfs-linux-fallback.img"
menuentry ' vmlinuz-linux & initramfs-linux.img & intel-ucode.img' --class snapshots --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-snapshots-7f6441da-512e-46ad-8c4e-9837a70421a6' {
insmod all_video
fi
set gfxpayload=keep
insmod btrfs
else
fi
echo 'Loading Microcode & Initramfs: intel-ucode.img initramfs-linux.img ...'
initrd "/timeshift-btrfs/snapshots/2023-01-03_16-00-01/@/boot/intel-ucode.img" "/timeshift-btrfs/snapshots/2023-01-03_16-00-01/@/boot/initramfs-linux.img"
Looks like the snapshot:
has been added. Or am I mistaken?
Unfortunately I donāt have a similar setup to troubleshoot/investigate it further ![]()
It is working!
I deleted all snapshots and rebooted. Then I created 10 new ones, booted to grub and they showed up! Then I deleted all those and created one new, booted to grub and only this new one shows.
Thanks!
I followed those instructions earlier, from the professor blog, but they wouldnāt work. I was tired though. It could have been as simple as that Iād lost track of testing and changes and forgotten to point it from the snapper directory to the timehift directory with
OK, so now it is working. What Iām wondering is: it seems that grub-btrfs in its current state isnāt working as intended. This will probably be fixed and updated. How will this affect me when I update, when Iāve incorporated inotify-tools?
And now this āhowtoā is irrelevant. It should in any case have been titled āWorkaroundā.
Iāll edit it to reflect this
The only āissueā that I could spot is that inotify-tools is specified as optional dependency.
$ pacman -Si grub-btrfs
Repository : community
Version : 4.12-2
Description : Include btrfs snapshots in GRUB boot options
Architecture : any
URL : https://github.com/Antynea/grub-btrfs
Licenses : GPL3
Groups : None
Provides : None
Depends On : btrfs-progs grub
Optional Deps : snapper: For snapper support
inotify-tools: For grub-btrfsd daemon
Since starting grub-btrfsd fails because of it not being installed, I think it should be specified as grub-btrfsā dependency.
Perhaps you might want to report it to the developer?
