How to use firewalld or else to block Internet connection of application (such as wps)?
purpose
I do not want some programs to connect Internet at background. not means wps do that thing.
On windows, there are diferents parts in wps. I can use a program(360, huorong) like firewalld to stop a part of the wps to connect the Internet. In most case, I will disable all parts of wps to connect Internet.
On linux, I find there is a tool called firewalld.
releant info
I have read Firewalld- arch wiki and search via Bing. such as How to Restrict Network Access Using FirewallD Ravi Saive July 18, 2020. These texts show how to block port/service/ip. But I want to know how to block a program. like firefox or wps.
  • firewalld : 1.2.1-1 enable and running
  • nftables 1:1.0.5-1 disable by default
I don’t think that Firewalld blocks applications, it blocks network traffic.
You might try opensnitch. I don’t use it but I believe it is capable of application level blocking.
